this is what im looking for and anyone with rock solid knowledge please reply only. Thankyou.
I need: Block height deck
Conrod length
Bore Size
Stroke
Piston compression weight
Combustion chamber volume
Main journal size
Rod journal size
Oil pump drive size. ie, are they the same and what year did they change
Port volume
& last of all for now Valve sizes
Possible monsta in progress but neeed to know how much is interchangable.
Thankyou Ryan
Edited by mad032
https://www.sau.com.au/forums/topic/157050-rb20-25-26-30/
Conrod length = 5"98
Bore Size= 86mm
Stroke= 85mm
Piston compression weight ???? =dont understand
Combustion chamber volume= 64cc for rb25/26, 53cc for rb30
Main journal size = really cant remember off my head got it written down at work
Rod journal size = see above
Oil pump drive size. ie, are they the same and what year did they change= not the same, change in 94 for rb26, others stayed the same i believe, N1 pumps are different.
Port volume= what exactly you after
& last of all for now Valve sizes 34mm inlet, 31mm exhaust rb26
https://www.sau.com.au/forums/topic/157050-rb20-25-26-30/#findComment-2917623
that one is more of a curiousity question.
and yes that was my bad... head on the side.
so can anyone fill in the blanks Fitzpatric speed works didnt?
I failed to mention that i need these specs for RB20 25 26 and 30.
Also need block deck height.
Ryan
https://www.sau.com.au/forums/topic/157050-rb20-25-26-30/#findComment-2920457
    • Hi everyone, just looking to see what's available in the GTR seat options, testing the waters on what's available. Wanting a driver's seat to replace my old school OG jap race seat, going to re-register the car so need a factory seat. Prices currently seem to go from $300 to $2k for a driver's seat. What's options are there, that's good condition and actually a realistic price? Located Brisbane. Thanks
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
