It would be a much better option to get your original engine rebuilt!
There isn't many second hand one's laying around, so there going to be costly.
Or you could goto a mitsu. dealer and get a new long or short motor.
I've had a customer do that before!
-Josh
https://www.sau.com.au/forums/topic/157068-mitsu-gto/#findComment-2917538
i seen em advertised at one of the import wreckers in the latest zoom magazine, cant remember the name of the shop but it was $3000 i think.
gto's are underrated in Oz, go check out 3si.org as mentioned and u will see the yanks rate the 4g63 up along side the 2jz for strength and potential :P buy one billet tf case and u have a damn strong driveline too as they are known to break tf cases. one gto ran 9.7 down the 1/4 mile and made 900awhp+ on stock internals :P and plenty are running 600awhp+ on stock internals and running low 11s and high 10s.
i got a gto and its an awesome car for daily use and zero lag with great torque, totally different style of engine to my rb26 thats for sure.
good luck
Edited by CruiseLiner
https://www.sau.com.au/forums/topic/157068-mitsu-gto/#findComment-2920945
  • 9 years later...
    • Haha watch Alex's eye twitch when you mention Nistune to him in person lol. He's not a fan, then again it's quite a niche product. I personally don't mind them, but most usually steer clear from it. Word of advice, do not ground the AFM to the chassis, there are heaps of incorrect guides on the interwebs. Send both GND on the AFM back to Sensor GND on the harness.
    • Note I edited my post, so Sleeper's quote is not the same as what I meant any more.
    • That's a whole 'nother issue. Nissan ones get dirty and sticky. The coolant heats the wax pellet thingo to close the valve, so it is open when it is cold. And so if there is no coolant it just takes longer to close, because the heat has to soak all the through the inlet manifold.
    • I feel like this is crazy pills though. Isn't it locked up all the time anyway? It shouldn't flare anywhere if it only unlocks momentarily while it shifts gears. And if it flares like that when shifting gears, then the 8HP with a 5500 stall is not driving as well when on the road and/or track use..
