you will need to trim the snorkel a bit for it to fit.
as for cutting the reo.. you can always sit the front mount further back but you probably wouldnt be using any 'off the shelf' piping kits as most are designed for the front mount to bolt up to the reo bar.
  • Replies 56
  • 2 months later...
Sorry to hijack the thread but does anybody have any pics of where their intercooler pipe comes through on the drivers side and over the top of the fan blades or wherever it goes???
Anyone that has installed these lately can you please let me know about the Inlet pipe to the intercooler. It is longer on one side than the other by about 3-5cm.
Does the longer piece connect to the old pipe coming through the hole in the chassis or does it connect to the intercooler inlet?
It seems that either would way might work..
You can cut them after the piping is fitted and the fan still on. Its probably better to do so, so you can check how much needs to be lopped off and check the clearance. As for cutting, we used a pneumatic die grinder with the cutting disc attachment. Or alternatively you could use some tin snips.
We spun the blade around and held a marker in one spot to evenly mark the blades.
Edited by KeyMakeR33
I gave you photo's of where the hole goes in you other thread.
http://www.skylinesaustralia.com/forums/in...20&start=20
Does anyone Know where to get a smaller type intercooler. I mean thinner like 50mm or something. That might suit this guys application better. I am trying to do the same thing too, i might go for a thinner cooler and try get something that has both outlets on the same side so that I can connect it back up to the factory piping.
Anyone know of places that sell thinner coolers and ones that have outlets on the same side.
Also i am not chasing any big HP figures so i think a thinner cooler might just do me nicely.
Just jap have a cooler that has outlets on the same side. I don't think its any thinner though and you would have to get some piping made for you.
Oh yeah i know but i mean does anybody have any pics with the pipes in place??
Cheers.
:D
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
