Join the club Paul (Technically I havent *sat* in it but I did lean on/drool over it)
:P
Im sure there have been many to drool over it....but to be able to sit in it, remove rear deck lid, open bonnet...heck we even got to push it around...lol.........but no starting it up....damn!!
ive even worked out what HKS stands for
Hello
Kitty
Seatpad
hehehe
Hello
Kitty
Seatpad
hehehe
na hks stands 4
Hong
Kong
Shit
HKS
H and K are the first letter of the last name of each the two owners
the S stands for Sigma i think.
So whats the deal did it run? did Reece Run any times?
HKS
you are correct on the HKS name...i was just having a joke...the Bride racing seat in the HKS car has a "hello kitty seatpad"
it did not run but here's some news about Reeces runs...
Heat Treatments GTR
The HT team didn't really expect to break any records at taupo. Despite this, the car still ran a solid 7.77, and then a 7.78. The 7.7 pass should have been quicker, as the car crept on the line and red lit before Reece actually launched (the timer starts from when the beam is broken). The next pass was looking great, with a PB mph to half track (152mph!!), but unfotunately the front diff broke in the 2nd half of the track. Becuase the front diff is integral with the sump, it also cracked this part, putting the car out of action for the afternoon.
Heat Treatments GTR
Yeah i knew you were joking as for the Hello kitty seat pad WTF were they thinking not my taste at all, thats one part i never liked about the HKS car :wave:
Had Reece changed anything on on the car?
lucky as. pics pics
Have realised our cable to connect camera to computer is at home....have to wait till we get back to Aust on Sunday.
Is there any particular parts of the car you would like to see....such as where they set the dials on the torque split controller ?
Na not really :D just every pic you took of it :D
Now hurry up and get on the damn plane :D
we lift the hood on the beast
standard coil packs are an interesting find
a big thanks goes to Daryl at Redline Performance for allowing us a few hours with the car
the lever closest to driver is for the parachute
all the ATTESSA pumps are relocated to the passenger seat area. There is normally a carbon fibre cover over these for asthetics which they allowed me to remove to photograph
note where they have the torque split set..the dots they have put on the unit indicate this is their true race position
i see they use a "DiRTgarage" style 4WD 2WD switch for burnouts
the famous Hello Kitty Seatpad
note the angled flange to change the direction the air enters the port
solonoids for air shift mechanisim
fuel system comprises of a small fuel cell and 3 bosch 044 pumps
dash is a simple as a shift light, a gear indicator, a brake pressure guage, a warning light (low oil pressure) and an oil pressure guage.
the result of no air filters...compressor wheel has certainly seen better days
the std boost guage sensor was an unlikely thing to spot
three stage dry sump pump..two scavenge pickups and one feed...keen eyes will spot the ATI balancer
this would be the heaviest hydraulic clutch ive ever operated.
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
