Hi all doe's anyone know if a r33 auto computer will run in a stagea?
We were thinking since stageas are soo detuned you could gain by using a 33 auto computer.
Doe's anyone know if this would create any problems or could this quite possibly work?
https://www.sau.com.au/forums/topic/157081-auto-computer/
different plug from memory, but im sure someone on here will know for sure
https://www.sau.com.au/forums/topic/157081-auto-computer/#findComment-2917787
Both the R34 and R33's have VVT on the intake cam. The difference is the R34 system is infinatly variable in adjustment, where the R33 system is on/off.
However, this doesnt seem to be an issue as Cyrus is running and R34 GTT powerFC in his R33 engined manual converted Stagea.
I dont know if the tiptronic/not argument has much basis either, as the box still works like an auto, essentially they are both the same, with the tiptronic feature being an add-on to the standard auto box....understand what I am trying to say.
Id be curious to see what would happen if someone tried it.
OH, on another note, there are a few sensor changes from R33 to R34, for example R34 RB25DET's have MAP sensors which tell the ecu how much boost the car is running, also a few of the pinouts on the R34 are different to the Stagea, namingly the injectors are on different pins (hence the car wont run plug out/plug in with an R34 ecu)
https://www.sau.com.au/forums/topic/157081-auto-computer/#findComment-2921665
I was talking to Beastian last night, he said he plugged his R34 PowerFC into his car, and it worked first go with nothing changed. It didn't drive as his car is still auto, but the engine worked. I don't think the injectors are on different pins if this happened
https://www.sau.com.au/forums/topic/157081-auto-computer/#findComment-2921820
Three of the injectors are definately on different pins, but they are just mixed around with each other, this is why the engine still ran, the injectors would be firing at the wrong time, but the timing is so close, it still ran under no load.
If you drove it like this you would definately notice it.
Also I have found out through someone in the forced induction section, and confirmed it with the R34 service manual and Stagea S2 service manual, that the VCT is basically the same between the R33 and R34, it's ON/OFF. The only difference is the R34 has been designed so it comes on alot more smoothly.
There are a few sensor differences aswell, but from studying the service manuals, they won't make any difference to the running of the engine. I think they are mainly to do with the more intricate R&R mapping that R34's have.
https://www.sau.com.au/forums/topic/157081-auto-computer/#findComment-2923825
So are you saying you can plug in a R34 GTT Powerfc into the S1 Stagea (auto or manual, it makes no difference if the auto has the MV shift kit), fire it up, and have it dyno tuned, and away you go?
Or is there more to it then just that ?
https://www.sau.com.au/forums/topic/157081-auto-computer/#findComment-2925522
Definately has to be a manual Brendan, Power FC has no facility or connections to control the auto box unfortunately.
I'll actually be starting my conversion this weekend, and the PFC will be going in afterwards.
I just wanted to plug it in and see what happened, Theres been a bit of talk about the R34 version not being compatible with the S1, and modifications being needed. I knew it would work because Ska's seems to work fine, and I thought I would be the next guinea pig, and work it out for myself. What I have found is very promising, and it's looking alot easier to acheive than first thought.
Once everything is finalised, I will gladly post my findings, and answer any questions.
https://www.sau.com.au/forums/topic/157081-auto-computer/#findComment-2926633
Nup.
Power FC in auto R33 RB25det does work
with MV Automatics shift kit
........... trust me ! :P
would love to pick your brain once its all done brendan, all the best 'bro
https://www.sau.com.au/forums/topic/157081-auto-computer/#findComment-2929603
Nup.
........... trust me ! :(
I'm almost certain, specially after looking at an R33 service manual, that they have a separate Auto trans ECU, unlike the stagea which is incorporated into the engine ECU. Thats the only way it could work.
Maybe it would be possible to put an auto ECU from an R33 into the stagea to control the transmission, and run the engine from a Power FC or such.
More than keen to share my findings mate :wave:
https://www.sau.com.au/forums/topic/157081-auto-computer/#findComment-2930323
  • 3 weeks later...
Nup.
........... trust me ! :laugh:
I'm pretty sure that I remember reading in an issue of HPI a while back they did a feature on Auto's with MV Automatics. And as well as the shift kits and other internal mods they do for autos they also have a little black box they've made where it bascially takes the control away from the auto ecu and makes it manual. As in it won't shift itself anymore you need to use the auto shifter to change gears (like 1st, 2nd, D = 3rd etc). This would explain what Tangels was saying. If this were the case then it wouldn't matter about using the PFC as long as it can run the motor, you'd just have to get used to changing gears with the auto selector.
https://www.sau.com.au/forums/topic/157081-auto-computer/#findComment-2986381
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their reliability is proven, performance can be predictable, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
