OK I've got a few sets of these left over from LED bulbs that I evaluated. They're great for parkers, not overly bright but do the job.
I've got 15 sets of electric blue, and 14 sets of HID white (pictured below)
Consisting of 2 x T10 LED globes for $10 delivered!!! Get in before the NS guys get onto them (their group buy apparently went tits-up!!!)
Brighter versions of both are available however, if you feel you need the extra oomph, they're $15 delivered and are also the same as offered in my dash kits due to the good spread of light they provide. (pictured below)
https://www.sau.com.au/forums/topic/157082-t10-led-parker-lights/
I've had a few queries about the brightness of the dash type T10 over the standard type parker T10 with 3 LEDs
On the right is the 6 LED ($15 a pair), on the left is the 3 LED ($10 a pair)
I'm using the 3 LED type as I'm not that phased over the brightness, just that they match my Xenons.
Dan ill buy a set of what your running as i also need to match the HID's... The $10 ones look fine to me mate...
Can you bring a set to the dyno day and ill pay ya then and there... :P
  • 1 month later...
  • 2 months later...
  • 1 year later...
got mine today very happy with them they aren't too bright and that's just what i wanted! highly recommended. only downfall was i had to take my front bar off to get to the LH light to take that off, to put the led in since the water and fuse/battery box thingo was in the way.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
