You just had to bring the bolt cretins into this didnt ya, but i had already throught about them and got them covered.
Every one knows if you hang full cans of WD40 around the shed it sort of works like garlic and vampires. The garlic bit worked on the missus so i have high hopes on the bolt cretin cure.
Edited by tacker
forget fairies, find yourself some underpants gnomes. we all know they work all day, searching for underpants yay, they won't rest till they find underpants.... and so on. they are very hard working providing you can deal with them singing that song non-stop.
I have my engine sitting on the floor in the garage and it looks like the biggest pos that was ever made.
Just looking at all the bits n pieces all over the place makes me nervous to touch anything.
Day 15!
i was down to the last can of beer i had used in vain in my turbo fairy trap. The very last can, nothing else but the makers name and that was written in french and partly obsucured in blood from my torn up hands.
Thought i better wipe some of the blood away with an old rag before putting it out of its misery. And bugga me if the beer can genie didnt pop out offering me 3 wishes.
Wish one, please please put the turbos back on me car, poof .....all done!
Wish two, Return all the beer the barstard turbos fairies drank while demolishing my engine bay. Poof ...........full fridge!
Wish three, stock up the other fridge so i can at least temp the pressure plate pixies to come and replace my clutch as it aint gunna hold on too long with 455 AWHP after dyno session today.
WHOO HOO
Edited by tacker
yep all at .9 bar so i still have a bit to play with i would think just flat lined at about 7200 when wastgates opened. We did higher runs for what it was worth but we add some more fuel just to be safe and have AFR's mid 11's.
BIG improvement came from adjusting the cam timing was about 40 to 50 more HP depending on how hot the car was on its run. But just so much more agressive on ramp up really big difference mid range.
Gee I hope this is not part of the fairy tale - 455hp.
Nah - well done. Big effort. It almost makes the pain worth it.
Let's hope mine goes as well. :)
yer not to sure about the figure myself or how you calibrate a dyno dynamics 4 wheel dyno. but either way it performs sooo much better
But what a difference in performance...my hands dont hurt half as much as they did early last week.
I dont know about the figure produced but the tuner didnt seem interested in the graph reading much at all. didnt move his eyes from the wide band or remove the det cans from his head, really didnt give a rats about the figure.
  • 9 years later...
  • 1 month later...
Pay some-one else to do it...If your not a mechanic...
Cost approx...$500 to $600.Engine in..."don't make them take it out cause their lazy."
This will cost another $500
The extras such as new copper washers/bolts/gaskets/oil and water lines"if needed"
can cost though.
Great explanation / DIY Turbo replacement for a GTR..
Old thread i know. ...but..pretty sure removing the whole engine to do a more thorough job isnt being lazy, its called do it once and do it right
I will be removing my engine before I put myself thru this kind of pain and suffering, I know just from looking that there is going to be many tears
Very funny writeup.
This is the solution though. There's no way in hell I would attempt to pull all that mess down with the engine in the car!!!
To add fuel to the fire, I can remove my BW 8374 EFR completely in about 45 minutes. There are 4 nuts, 1 V-band clamp, 1 hose clamp, 1 vacuum/boost line, and 4 AN fittings to/from it. All very very accessible.
But in all honesty I did contemplate staying twin for a long time. But I DEFINITELY would convert to speed density (Haltech or other) by removing the MAF's remove ALL BOV piping spanning from the driver's side of the car over to the intake piping and change them for BOV's that don't open under part throttle, and just simplify the inlet / outlet piping in general. I think half the hassle is simply getting TO the turbos. I can't imagine trying to find a boost leak in that mess.
It can be done in the car and works without issue. How is it anymore thorough? Totally unnecessary to remove the engine!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
