Hi Guys
I was just wondering if some or most of you guys who have R33 GTST have upgraded your clutch and brakes from the stock ones. Have most of you upgraded cos you have greatly increased boost/power and it is a requirement? Have you found them to be a great investment?
Have you guys also upgraded your suspension too? Is it a good upgrade to consider or does the stock suspension work good enuff?
Also what have you changed these parts to?
Thanx
Kev
I suppose it depends on what you want to do with a car.
Oh... and i drive an R32, and on the street i drive like Morgan Freeman in Driving Miss Daisy.
Suspension.
I was happy with King Springs, little lower for mainly aesthetics, for the street. Drove nice, a little less roll, but no susp setup will allow you to fly around corners on Syd roads, (nor should you really want to) bumps/potholes/children. With me behind the wheel i think i would have struggled to find the limits of the chassis with this setup on the road.
But when i first started venturing onto the track i found the car wasnt that impressive so made sensible mods to improve handling whilst still preserving my sanity on the street. Bilsteins, sway bars, strut braces, bushes, alignment
Clutch
My thing was starting to show duress after numerous trips to the track. So before it caused possible gearbox damage i upgraded to a 6 puck sprung centre clutch with lightened flywheel.
For the street though my stock clutch was holding up fine remembering i only have IC/exhaust/filter/boost.
Brakes
I would like to believe that you would never approach the limits of the Nissan brakes on the street, (if serviced and functionining to their potential) As they held up extremely well on the track. You would have to show some mercy to make sure they lasted 20 minutes of abuse, but i cant see such a level of performance ever being required on the street.
That said when i cooked some pads one day at the track i did some damage to rotors as well, so seemed like the time to upgrade. Having rebuilt calipers/master cylinder/booster and running braided lines i was advised that larger rotors is all that i needed. So now have 330 x32mm rotors and the car stops like a champion for full 20 minute session (remember i only have about 150rwkws at best) Dont have to show them any mercy at all.
I have noticed that the brakes do work harder when running good rubber on the track vs crappy road rubber, which i suppose makes sense. With say another 40-70+kws and running soft rubber i have been advised that better calipers and floating discs would be ideal.
So me thinks for the road, provided the OE gear is in good nick, then springs and clutch (say around $1000) is all that you would need. Brakes some good pads and fluid works wonders.
But if you have the coin...
Thanks for the opinions roy.
I probably wouldn't venture on the track anyways, so I guess some of the performance improvements you experienced would not be felt on normal roads.
U reckon there is any need for strut braces on the road? (or do they just look cool in the engine bay) :D
Brake upgrade: The DA slotted rotors and EBC greens front and rear have dramatically improved the braking performance. Shorter stops, less fade. Pads will squeek at low speeds but stop after a couple of hard stops as dust is removed.
Initial bite tends to cause front lock up when emergency stops, not a problem for me as I have ABS, but can be avoided by applying brake pressure lighter and ramping up as weight tranfers to front (just like a motorcycle).
  • 1 year later...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
