*shrugs* if you have the money I don't see whats wrong ith doing it... Expect to pay upwards of 10G just to get the motor in their... not to mention gearbox, custom tailshaft, wiring up the electrics etc...
It's sure be different. You wouldn't be thinking about re-sale value. If done right it'd be unique and quick! and the. THis months auto salon magazine has an e36 with a 2jz in it.
in all honesty people here are going on about resale but why??????
does anyone modify a car for its resale value? if you modify a car you never recouperate your money anyway.
personally i think its a great idea. who cares what engine was originally in it, provided your making an improvement
My mates workshop (GT Auto Garage) did an RB25DET conversion into an E36 318i last year. Wiring was a mission, fitment was not the drama that alot of people said it was going to be since they used the Greddy intake plenum. Was a very successful conversion apart from smashing a few diffs before an M3 rear end was sourced. Car is now running fine to this day.
  • 3 weeks later...
What model is it? Are we talking a 316ti or a 330Ci, coz there's a big difference from one end of the three series scale to the other. Anyways, I've seen an E36 with a 2JZGTE, so one would expect the E46 to swallow it also. 2JZ is better than RB anyways.
*hides behind flame retardant barrier*
No barrier needed. i believe that the 2JZ is a better engine than any RB. However, just because the engine is better, doesn't mean the car is better.
i.e. rb26 vs 2JZ - 2JZ seems to be the better motor. GTR vs Supra as a car to drive? GTR is the better overall performance car.
now i need that flame retardant barrier!!! :nyaanyaa: :nyaanyaa:
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
