i know the sierras were running massively high boost, i remember watching them when i was a kid
i was so stoked when we went to the UK with the family, that our hire car was a sierra (non turbo, bodge version)
I had a look at them at the bathurst museum 2 years ago...massive turbo too!
Got this on DVD, great to watch.
It would be great to see this brought back, Group A touring that is.
djr81, just because they lead by so much didn't mean they were going to win. Really the other car companies needed to come to the plate with their cars and build something decent. Instead they changed the face of australian racing to give the cheaper local manufacturers a go.
Just because back then the rules needed to be tweaked and cars needed to catch up to the GTR doesn't mean it was a bad time. But instead of everybody coming to the plate to create better cars, they changed the rules and changed australian racing forever.
Talk on the net, a lot of the older people still remember the Bathurst races and they were known world wide.
I'd love to see Todays M3, Evo's, GTRs and WRX's getting around the track along with Monaros, XR6 Turbos and Ford GTs. But instead we are stuck with the v8 super cars...
"Just because they led by so much didn't mean they were going to win."
No, they did occasionally break down.
What you need to take account of is the reality that by late 1990 the group A category was on its last legs. Most companies who had previously been actively involved ceased doing so. Most of the homologation specials had by that time been finished & there was very little factory development. It just so happened that Nissan were (other than BMW) one of the last companies to bother homologating cars to the regulations. For instance the Sierra was eligible in '87 in its evolution form. It was still doing the rounds 5 years later - which in motor racing terms is an age.
There was no chance that the group A formula could continue. As an international formula which required factory backing it could not survive without such backing. It was a case of which formula to replace it with 2 litre or 5 litre. Given the state of the BTCC presently I think it is a bit churlish to criticise CAMS for picking up on the 5 litre category.
Lastly production cars racing was never Australias premier formula. Even back in the early 70's the improved touring cars were more of a headline act than the production cars - Bathurst aside. Even if you do include Bathurst the most famous race there was an improved touring car race. Geoghegans Falcon versus Moffat's Mustang. Basically the growth in production car racing/improved touring car racing can be traced to the decline of the Tasman series from approx 1969 onwards. Production car racing still survives today, but at a much lesser level than the topline categories. It is still worth watching, however.
If you like your old school motor racing I would suggest checking out Late Night Legends on ABC 2. They periodically show old stuff, mostly from Warwick Farm. The shot below is of Pete Geoghegan in his Falcon (with tyre smoke) chasing the Camaro of either Norm Beachey or Bob Jane (Yes that Bob jane). Can't quite remember which.
Edited by djr81
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
