Finally after hearing rumour whispers for some time I found this article/picture:
S16 Silvia
Can anyone translate Japanese? Not sure on authenticity but it looks like a possible evolution of an S15. Mmmmm SR20VET - 207rwkw from the factory!
https://www.sau.com.au/forums/topic/15714-s16/
Hey, cool an S16 SR20VET... but that's funny, I thought they have killed off the Silvia due to high emission problems like the Z’s and Skylines old VG and RB engines... Australia is still getting the last few shipments of the S15 until August, I believe?
Well it good to see an S16 in the flesh, and… I WANT ONE!!!
Graham
https://www.sau.com.au/forums/topic/15714-s16/#findComment-321416
Graham - no the last new S15s were sold last September .... you will only find second hand ones around now.
Hiep - it's like Honda V-tec .... new kind of VVT - I'm not sure on the precifics but it makes the motor a hell of a lot more efficient, powerful and has less emissions. The 2001 Nissan X-Trail 4wd JDM version had the motor in it! Not the AU version though.
Robert - I want one too mate :D
https://www.sau.com.au/forums/topic/15714-s16/#findComment-321517
looks like a pretty bad photoshop to me, those headlights are very crooked S15 lights stuck on something else.
I'd be surprised if they didn't replace the S15 line sooner or later, 350z is too expensive for entry level. quite possible it wouldn't be turbo though, so I'm not sure how keen everyone would be then.....
https://www.sau.com.au/forums/topic/15714-s16/#findComment-321556
It could be a photoshop, but those lights are nothing like an S15 man .... have a look at the number of globes in there (small indicator and other globe above it) .... plus they have far too much height. S15 headlights are more long and thin. But I agree the headlights on the pic are dodgy.
https://www.sau.com.au/forums/topic/15714-s16/#findComment-321565
Yep... I'll have to agree the lights are photoshopped! The shape of the nose lines are little bit like on our Australian Mitsubishi Magna! :)
I had to edit this in... as after I exploded the picture there is an obvious photoshop around the C-pillow, boot and rear fender as well! Hmmmm... overall a poor job!
After checking the dimensions the S16 will be 135mm longer, 5mm wider and 75mm higher than the current S15... I wonder what the wheel base, wheel track widths and weight would be???
Graham
https://www.sau.com.au/forums/topic/15714-s16/#findComment-321846
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
    • Do I have a series 2 or has someone spent money to have a series 1/1.5 look like a series 2? Everything I have read says the series 2 came out in 1996. I have a car manufactured in December 1995. The exterior, engine and interior are all series 2 other than the dash facia is series 1. Paint code is also kr4 that I believe is only available on a series 2. I have a VX Vehicle History Report and it says Grade: GTS25T TYPE M2 Manufacture date: 1995-12 Make: NISSAN Model: SKYLINE Body: E-ECR33 Grade: GTS25T TYPE M2 Engine: RB25DET Drive: 2WD Transmission: F5
    • I went to Repco to get them to test the battery using their tester (not a volt meter), alternator shows 14.3v when running, and when the car was off after the it was on full load I think it was 12.6v but the guy said it was all good. Terminals are all clean, no corrosion. Though I coulda sworn when I tightened up my alternator belt the car idles a bit higher and the steering wheel shakes a bit until it's warmed up. I wanted to confirm for the earth cable/s, are you referring to the 2 wires that are bolted onto the frame rail under the battery? I might be overthinking this a bit.
