Hi guys Im new to this site and I thought I would post a few pics up of my R32 drift pig. From experience I would have to say that a 32 is easier to slide than an s13 plus its a skyline haha. RB20's are the bomb. This car lived on limiter while I had it and nothing broke at all except for the stock turbo.
Heres a pic of the thing after me and some mates got got wasted and decided we were fullsick (sarcasm) graffiti artists haha $.post-35562-1171911349.jpg
I live in Townsville and I bought it from some dude down on the coast for $7k with a roadworthy (dunno how he got it cause every thing but the engine was stuffed).
List of mods:
Replaced stuffed shocks with less stuffed JIC coilovers
rb25 turbo (rear wheel on the stocker cried enough and tried to escape out the exhaust).
front mount
screamer pipe off the internal gate
set of 18 inch dishies (nicked of my soarer)
gtr drivers seat
nismo 2-way diff
new r32 gearbox
new exedy clutch
front and rear strut braces
tubosmart bleed valve set at 0.9 bar
made 162 rwkw on dyno dynamics dyno
The rest of the pics show it in various stages. Anyhow me and a mate from uni ended up giving it a backyard 2pac paintjob in that baby blue commodore colour and fitting a URAS kit.
Just sold it and I thought I'd be happy just cruising around in my soarer ( manual got a Trust T78-33d ) but Im having RB withdrawls so if anyone is selling a manual R33 gts25t for $11-13k pm me.
Edited by RBdrift
https://www.sau.com.au/forums/topic/157140-my-r32-slider/
markimak. yeah in hindsight it was pretty foolish. but the paint was shagged anyway so it didn't matter.
In the end it turned out OK and I had to sand all that crap off of it while prepping it for paint so I learnt a fair bit at the same time.
Dude if you think I would do that to a clean GTR like yours or something, you are mistaken :laugh:
Edited by RBdrift
https://www.sau.com.au/forums/topic/157140-my-r32-slider/#findComment-2921137
Dude if you think I would do that to a clean GTR like yours or something, you are mistaken :(
haha.. things ppl do when drunk..
anyway.. gl with ur R33.. :D
https://www.sau.com.au/forums/topic/157140-my-r32-slider/#findComment-2927028
    • 2 spots that my exhaust guy joined the 2 pipes together  Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
    • Hi all, considering clutch upgrade to support 1130 engine hp from 1650cc injectors on e50 at 85% duty cycle (1650 x (11.85/14.7) x 85%). Narrows down to these three as they can be converted to use gm 26 spline input shaft if I ever want to use transmission with that input shaft (orc1000f and r3c easy/cheap just change center hub; tr2cd pricier must change clutch discs). Pricing orc1000f similar to tr2cd, r3c about usd 200 pricier. Orc1000f triple plate 200mm. Tr2cd twin plate 215mm. R3c triple plate 215mm. Claimed max torque : orc 1000f 723 lbs ft; tr2cd 800 lbs ft; r3c 1100 lbs ft. Why orc1000f triple plate but claims lower max torque vs tr2cd twins? Is orc1000f underrated? Any info maxing out these clutches? Info on street/traffic driveability/pedal feel? Thank you for any info on them.
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
