Just be sure to back up your desktop, my documents, and favourites, and any other stuff you may want before you wipe the disk. You should only need to do a quick ntfs format, win xp is a pretty straight forward install, the only pain is reinstalling all the software and mabey a few drivers, then copy and paste your data from the backup, good luck :wave:
you have to go into bios and change your boot sequence so it boots from the cdrom first then hd.
i bought myself another larger hd(pretty cheap nowdays) and wacked all the stuff on to that then re installed on the old one. its pretty handy. also with a bigger hd you can partition c drive to just 20gigs just for windows and store all your other stuff on another partition. so if you ever need to format again it'll only be that 20gig c drive thatll need it. saves you burning stuff to dvd.
"you have to go into bios and change your boot sequence so it boots from the cdrom first then hd."
If I knew what this was then I would do it. Im thinking putting the XP cd and letting it work its magic. The HD idea is alright but dvd's are cheaper hehe.
When your computer first boots it will say something in the corner like
"press DEL to enter bios"
press the key until it boots into your bios. Then under one of the tabs will be
"boot sequence"
it will probably be something like this
1st Device - HDD
2nd Device - CDROM
3rd Device - None
make the first device CDROM
then save and exit from the bios.
Make sure your xp cd is in the drive then it will reboot, and say
"press enter to run from cd"
do that and follow the prompts. Fairly straight foward.
"boot sequence"
1st Device - HDD
2nd Device - CDROM
3rd Device - None
Thanks more like it!!! Ive also been told I can just get a boot disk and use this.
Just wondering if you dont have all your discs to install all the appropriate drivers, Anyway to get them from the current unformatted computer? Not to sure i have the drivers for the important things like internal video/audio cards and stuff are these drivers included in the windows xp cd?? Or your pretty much stuffed??
Most of those drivers should of come on CD's with the computer.
Motherboard, graphics card, etc, etc drivers.
Don't worry though cos XP is pretty good at getting up and running.
Then once you connect to the net you can go to the hardware vendors website and download the appopriate drivers.
Pretty much everything I would have said has been said.
Skip the boot disk and just boot off the cd (assuming it's a legit or at least half decent copy of XP)
If you've never touched the bios then chances are it's already set up to boot from a cd first. Try and just stick the cd, reboot and see what happens, if it goes straight into your old version of Windows then look at changing the bios boot settings.
As mentioned, look at partitioning your drives into at least 2 different partitions. It makes the format & reinstall process much easier in the future.
Otherwise it's all pretty easy, XP shouldn't have any problems getting the system up and running, even if you're missing driver cd's. After it's up you can just hop on the net and download the lastest manufacturer versions anyway.
Well would their be anyway that I can tell what I have on the computer in regards to drivers and so i know which websites to go to download just incase i dont have the cd's or documents which tells me what hardware my computer has.
I'm currently on Win 200 atm and can't remember if XP is different but
Right click on My Computer -> Properties -> Hardware -> Device Manager. (Otherwise just look for device manager in System Properties)
Just write down say the following:
Display Adapter (Video Card)
Netword Adapters
Sound Controllers/cards
Everything else XP should have no problems with. After the install, do the same thing and look for any devices with a yellow ! over them. They're the main ones you'll need to find drivers for. That and I'd recommend downloading the latest video card drivers as well.
Netword Adapters
Excellent :sick: this would also let me know about the motherboard and all that stuff right.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
