Does anyone know FOR SURE (not "I think") if the pits will pass a full cage that doesn't hinder your legs while getting out of the car, but does go through the dash?
Also has anyone here actually registered a car with a half cage as a 2 seater? Do they require the rear seats to be in or out?
Because they don't want to give a consistant answer. I've been told that they don't do full cages, that they will only do a 2 seater with a half cage if the rear seats aren't fitted, and they don't do a 2 seater with a half cage if the rear seats aren't fitted.
3 different people, 3 different answers.
http://www.dotars.gov.au/transport/safety/...on_3Feb2006.pdf
page 33 will tell u everythin u need to know. That is the national DOTARs regulations hand book so as long as u build to them guide lines u will b fine and can get half cage permitted. Full cage is strictly NO but u r allowed to have mounts to bolt in front bars for off road/ track use
thanks for the linky, that covered everything.. good on ya mate.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
