Bosch 040
They aren't actually rated by horsepower, they are rated by their flow rate and pressure at which they flow fuel.
040's are rated at 168 litres per hour at a pressure of 5 bar, generally this is good for between 350 - 400 hp, which is why ppl say they are rated at 380hp etc.
still for sale!
Cheers,
Dave
not 100% sure what modifications are required as I've never actually put one in, but from what I hear it is pretty straight forward, there should be alot of info if you search for it.
Cheers mate.
I've actually heard these pumps fall in 32's 34's and s15's but 33's is a bit more screwing around... free bump good luck with selling the 4 :D
  • 4 weeks later...
$10 dollars to send to anywhere in australia. Guaranteed they are 100% genuine brand new bosch 040 fuel pumps. Bump.
dude you still got the 040 ill like to buy one ill come pick it up today if you can provide me with your contact details or you can call me on 0433188959 cheers
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
