hey again
wanna run my car down the 1/4 as i have previously stated but i want to be realistic and run with my street tyres.. i got 18 in rims on it now and wanna know what tyre to go for... either a 255/35/18 or 245/40/18?
a friend told me to go for the 245's cause of its higher profile.
i have no clue..
https://www.sau.com.au/forums/topic/157365-2553518-vs-2454018s-for-the-14/
You will probably get a faster time with smaller inch rims..
Im no expert either..
but i remember when i was at the drags, a guy from this forums put his stockies on and got a much better time than his 18 inch rims lol...
Anyways i dont think you will find some difference between them.. It will come down to your launch, and how well the rubbers grip..
Do the 255s, have better rubber than 245s??
im not too sure but a friend who works with tyres told me that the 40 profile is better for the strip
the larger profile will give you more grip as the side wall will have a bit more flex so in s triaght line you the tire wont spin up as easily, i would also lower your tire pressure to give you a geater contact area with the road
have fun at the drags
I'd say there would not be much in it running the 18s.
The 255 gives you up to 10mm more width. I say up to as a tyres width rating is a maximum width allowed meaning it could in fact be smaller. Wheels or Motor mag did a tyre comparo a while ago with a variety of 245 wide 17s and only one make of tyre (the cheapest) actually measured up to 245 wide, the rest were all narower.
The 245 tyre will give you around 9mm more sidewall which is ideal for drag but make your overall diameter 18mm taller.
I guess if one had to be chosen it would be the 245 but thats assuming both tyres are the same make etc.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
    • I managed to get the foam will the original upholstery off in one piece, so will be an easy to re fit thankfully.
    • Then eventually someone in a Tiguan MK2 with an email toon and some random Alibaba pipes. (FWIW, I ran a 12.9s down the 1/4 in the wife's car)
    • Not much. It's barely more than an hour's labour. So that-ish plus a boot, clamp strap, some grease.   But, being an R32 GTR, when it is up in the air and the driveshaft is out, about $9k worth of other problems will become visible.
    • Yes, as above. The welding is an easy enough job. Proper reupholstering, perhaps less so. These, and pretty much all seats of the same era (and probably still) rely on molded foam parts to make the shapes. That foam is the yellow detritus visible in the photos. And it is difficult to replicate. I didn't want the pain, so went aftermarket seats instead. But for "saving a classic".... it's probably worth the kidney and left nut that a trimmer will want to redo them.
