R33GOD Posted February 21, 2007 Share Posted February 21, 2007 hey again wanna run my car down the 1/4 as i have previously stated but i want to be realistic and run with my street tyres.. i got 18 in rims on it now and wanna know what tyre to go for... either a 255/35/18 or 245/40/18? a friend told me to go for the 245's cause of its higher profile. i have no clue.. Link to comment https://www.sau.com.au/forums/topic/157365-2553518-vs-2454018s-for-the-14/ Share on other sites More sharing options...
r33_racer Posted February 21, 2007 Share Posted February 21, 2007 think your in the wrong section buddy...someone should move it soon enough. Link to comment https://www.sau.com.au/forums/topic/157365-2553518-vs-2454018s-for-the-14/#findComment-2922298 Share on other sites More sharing options...
siddr20 Posted February 21, 2007 Share Posted February 21, 2007 You will probably get a faster time with smaller inch rims.. Im no expert either.. but i remember when i was at the drags, a guy from this forums put his stockies on and got a much better time than his 18 inch rims lol... Anyways i dont think you will find some difference between them.. It will come down to your launch, and how well the rubbers grip.. Do the 255s, have better rubber than 245s?? Link to comment https://www.sau.com.au/forums/topic/157365-2553518-vs-2454018s-for-the-14/#findComment-2922319 Share on other sites More sharing options...
R33GOD Posted February 21, 2007 Author Share Posted February 21, 2007 think your in the wrong section buddy...someone should move it soon enough. ahh alright i see where i gotta post this one lol soz Link to comment https://www.sau.com.au/forums/topic/157365-2553518-vs-2454018s-for-the-14/#findComment-2922320 Share on other sites More sharing options...
R33GOD Posted February 21, 2007 Author Share Posted February 21, 2007 You will probably get a faster time with smaller inch rims.. Im no expert either.. but i remember when i was at the drags, a guy from this forums put his stockies on and got a much better time than his 18 inch rims lol... Anyways i dont think you will find some difference between them.. It will come down to your launch, and how well the rubbers grip.. Do the 255s, have better rubber than 245s?? im not too sure but a friend who works with tyres told me that the 40 profile is better for the strip Link to comment https://www.sau.com.au/forums/topic/157365-2553518-vs-2454018s-for-the-14/#findComment-2922321 Share on other sites More sharing options...
Green_s13 Posted February 21, 2007 Share Posted February 21, 2007 the larger profile will give you more grip as the side wall will have a bit more flex so in s triaght line you the tire wont spin up as easily, i would also lower your tire pressure to give you a geater contact area with the road have fun at the drags Link to comment https://www.sau.com.au/forums/topic/157365-2553518-vs-2454018s-for-the-14/#findComment-2922348 Share on other sites More sharing options...
FATGTS-R Posted February 27, 2007 Share Posted February 27, 2007 I'd say there would not be much in it running the 18s. The 255 gives you up to 10mm more width. I say up to as a tyres width rating is a maximum width allowed meaning it could in fact be smaller. Wheels or Motor mag did a tyre comparo a while ago with a variety of 245 wide 17s and only one make of tyre (the cheapest) actually measured up to 245 wide, the rest were all narower. The 245 tyre will give you around 9mm more sidewall which is ideal for drag but make your overall diameter 18mm taller. I guess if one had to be chosen it would be the 245 but thats assuming both tyres are the same make etc. Link to comment https://www.sau.com.au/forums/topic/157365-2553518-vs-2454018s-for-the-14/#findComment-2939817 Share on other sites More sharing options...
R31Nismoid Posted February 27, 2007 Share Posted February 27, 2007 Tyre brand/quality is going to gave more effect than the marginal differences you have listed in a street tyre Link to comment https://www.sau.com.au/forums/topic/157365-2553518-vs-2454018s-for-the-14/#findComment-2940185 Share on other sites More sharing options...
psi Posted March 1, 2007 Share Posted March 1, 2007 Compound of tyre is very important! like nismoid said! tyre side wall will aid grip. don't forget about the evils of weight! then the rolling diameter! choices! Link to comment https://www.sau.com.au/forums/topic/157365-2553518-vs-2454018s-for-the-14/#findComment-2945969 Share on other sites More sharing options...
