  • Replies 61
Posted Images
S1 coilpacks are different from S2...S1 has a separate ignitor box, S2 has them built into the coils.
S1 coilpacks will fit but you need to splice an ignitor box between the coils and the ecu.
oh ok, thanx for that.. still need to know whether shanes are for s1 or s2.. SHANE WHERE R U!! ulazy prick :ninja:
https://www.sau.com.au/forums/topic/157370-hi-all/page/4/#findComment-2958228
