nice work mate, veryvery well done. i noticed your carbon canister lines have been 'chopped'. why don tyou have one of those? its the two lines that you have put the screws in...
Photo was taken when we chopped the paint tin size carbon canister out, I have since purchased a standard size carbon canister and put it back in.
So what was coated for the $210 ?
just plenum and piping? or the engine covers as well ?
plenum, intercooler piping, cam coveres, strut brace mounts, radiator mounts. I chose 2 different colours (the silver and dark blue) which made it more expensive (Min charge of $50 per new colour). If you want all the one colour it will prob. be a bit cheaper. Powdercoating is very cheap if you go to the right place.
I am not that happy with the colours, the cam covers turned out a lot bluer than I wanted, I was after a gun metal grey look but had to re-choose the colours I had chosen because I chose the only range that they did not have in stock.
Forgot to add that the pearl flakes etc cost a little bit extra with the powdercoating.
  • 2 years later...
Ah yeh woops sorry. I see the braided lines now. I think I might have been looking at a different pic.... possibly this one: http://www.skylinesaustralia.com/forums/Pu...80&start=80
But yeah, my question still stands... regarding the tube from radiator-to-coolant bottle and the tubes which "look-like" they are attached to his power steering fluid reservoir.
The only reason i sound like a broken record asking the same stuff over and over again...is because i've been getting mixed answers from a few people (I'm a total amateur when it comes to stuff under the hood). So sorry for that.
I did notice a weird thing though... I replaced one hose which was for air/vaccum (it was previously disconnected anyway, it had worn out and broken off from where it was attached) and my Boost guage needle started flickering? previously it had just been lying still at the bottom when the car was turned on. Not sure if this is normal.
to help you out a little..
i have used a cheap rubber "dress up" hose from my radiator tro overflow bottle for a long time and also for my breather pipes.. its had no dramas. its not silicon and is very flimsy but has held up for a few years now.
proper silicon hoses can be used for coolant lines to a bleed bottle etc.. aslong as they are clamped good. they are usually 3mm thick and being silicon they are very heat resistent.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
