nice work mate, veryvery well done. i noticed your carbon canister lines have been 'chopped'. why don tyou have one of those? its the two lines that you have put the screws in...
Photo was taken when we chopped the paint tin size carbon canister out, I have since purchased a standard size carbon canister and put it back in.
So what was coated for the $210 ?
just plenum and piping? or the engine covers as well ?
plenum, intercooler piping, cam coveres, strut brace mounts, radiator mounts. I chose 2 different colours (the silver and dark blue) which made it more expensive (Min charge of $50 per new colour). If you want all the one colour it will prob. be a bit cheaper. Powdercoating is very cheap if you go to the right place.
I am not that happy with the colours, the cam covers turned out a lot bluer than I wanted, I was after a gun metal grey look but had to re-choose the colours I had chosen because I chose the only range that they did not have in stock.
Forgot to add that the pearl flakes etc cost a little bit extra with the powdercoating.
  • 2 years later...
Ah yeh woops sorry. I see the braided lines now. I think I might have been looking at a different pic.... possibly this one: http://www.skylinesaustralia.com/forums/Pu...80&start=80
But yeah, my question still stands... regarding the tube from radiator-to-coolant bottle and the tubes which "look-like" they are attached to his power steering fluid reservoir.
The only reason i sound like a broken record asking the same stuff over and over again...is because i've been getting mixed answers from a few people (I'm a total amateur when it comes to stuff under the hood). So sorry for that.
I did notice a weird thing though... I replaced one hose which was for air/vaccum (it was previously disconnected anyway, it had worn out and broken off from where it was attached) and my Boost guage needle started flickering? previously it had just been lying still at the bottom when the car was turned on. Not sure if this is normal.
to help you out a little..
i have used a cheap rubber "dress up" hose from my radiator tro overflow bottle for a long time and also for my breather pipes.. its had no dramas. its not silicon and is very flimsy but has held up for a few years now.
proper silicon hoses can be used for coolant lines to a bleed bottle etc.. aslong as they are clamped good. they are usually 3mm thick and being silicon they are very heat resistent.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
