and well no ticking when cold, only when hot.
this is the final proof you need it's the manifold or dump or turbo gasket. as when cold everthing is nicely sealed. once things heat up and start to expand your leak begins.
wogs, it's all to do with the quality of the gasket material.
I'll give you an example. With aftermarket gaskets, say like the dump gasket, they're usually two pieces of thin foil with goo sandwitched between.
Those are pretty crap, and don't last that long. The crap in the middle can get blown out and it leaks.
The genuine nissan dump gasket/turbo to manifold gasket is a solid metal gasket. I think it's copper.
It's really hard work to do all the gaskets/studs. As 31nismoid said, it'll be 6-800 if you get a workshop to do it, and the same amont of work if you do it yourself.
That's why I always use genuine gaskets, coz I don't want to have to do it again.
Think of it this way, your nissan gaskets have lasted 10 year. If you do it now, it'll last another 10. That's not much in the scheme of things. If you use goo gaskets, they might blow in 2 years.
If the gasket material of the aftermarket gasket is good, then that's cool. use it. but check it. don't get it just coz it's chepaer
Hi,
Can you hear the ticking pretty easily when standing next to the side of the car or do you actually have to be under or in the engine bay to hear it? Reason I ask as mine makes a ticking noise when cold but I notice it dissapears when hot. I noticed it after I changed to a different brand of oil. I went to Motul instead of Mobil 1
Cheers
Chris
you can hear it slightly if the bonnet is shut and standing next to the car, but if you put your head down, you can hear it easily.
I have also swithced to a different oil, however i do not think that is my problem. Time will tell.
[Threadjack]
I have a strange ticking noise when I give my car a little rev, dont think it's the injectors. On idle there is no ticking but if I rev it to say 2000rpm it's ticking while rev goes up. If I hold the rev at 2000 it doesn't tick. It's only there when I rev it :)
[/Threadjack]
  • 3 years later...
Hey guys,
Sorry for the thread digging - but I like searching for past info then dump the same problems in new threads. I think I've got the same gasket problem mentioned here but need your guys advice!!
Anyway, I drove hard at Eastern Creek on friday - on the drive home out of nowhere I start hearing this noise - similar to what has been said in the above posts.
It's a ticking sound, pretty much coming solely from the turbo. Here's a vid I took.
The coilpack cover/turbo heat shield and other bits and pieces have been removed to specify the source of the noise, there usually in place normally.
What do you reckon? Gaskets?
Oh, I should also add
oil pressure remains fine, car feels very underpowered, still on stock boost, but I can get maybe around 5psi out of the turbo if i give it a real bootful (which I'm not really inclined to do)
Mods are:
3" turbo back
FMIC
Turbosmart boost tee
Stock ECU
Change tha damn gasket Floyd!!
It sounds like the manifold to turbo gasket has blown out a part of the gasket.
Replace with a new genuine nissan one and it'll be sweet!
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
