I am thinking of running my car on this fuel.
I know it will make it run leaner per the same amount on fuel injected due to the oxygen content.
Say I was running a 12.5:1 AFR with ultimate, what would it be running at if I swapped to E10 with no tuning changes? I'm just trying to get a rough idea how much more fuel flow I would require.
After AFR's have been restored. Will it take more or less ignition advance than normal fuel?
  • Like 2
https://www.sau.com.au/forums/topic/157439-98-e10-tuning/
Mate, i read an article in one of the performance mags where they got an R32 GTR and ran a full tank of Optimax and put it on the dyno and it spun up about 250Kw at all 4. They drained the tank and put E10 in but didn't change the amount of fuel and advanced the timing due to the fuel being more stable and got an extra 20Kw at the treads by just changing fuel and timing. If your interested i'll try and find the article.
I'm running the E10 in my R32 GST-T with HKS2540, FMIC, 9 pound boost, full 3 inch with dump pipe and i think there onto something coz my car runs better in general revs out smoother and get better economy, I can't wait till i get enough money together to get my Apexi Power FC tuned (still on the shelf in my room).
Hopefully i can get the tuner to do a before and after dyno read out with different fuels.
Anyway thats my 2c, good luck :domokun:
  • Like 1
https://www.sau.com.au/forums/topic/157439-98-e10-tuning/#findComment-2923572
I think I've read the same article. I believe the outcome was it let you run timing similar to race gas but compared to the same amount of petrol it runs a few points leaner so you have to add slightly more to get the AFR's right.
Liter for liter E10 has less energy content over non-ethanol fuel so you will lose some economy .
https://www.sau.com.au/forums/topic/157439-98-e10-tuning/#findComment-2923653
Anyway thats my 2c, good luck :)
Was that E10 98 or E10 100? It would be sweet if you could find the article.
Frost. Yeah it might chew a little bit more but it costs way less from united servos.
https://www.sau.com.au/forums/topic/157439-98-e10-tuning/#findComment-2923768
haven't used 98 E10, use 100 E5 (Shell V Power Racing) all the time. Slight change in A/F ratios (leaner) not enough to stress over. But big advances in ignition timing, much faster boost build (standard turbo at 10 psi at 1,800 rpm) and much better throttle response.
Shell V Power Racing works great on the default Power FC Maps, virtually zero knock.
:( cheers :P
https://www.sau.com.au/forums/topic/157439-98-e10-tuning/#findComment-2925740
:happy: cheers :laugh:
Nice! So if you were running on the edge of detonation boost wise (23psi :laugh: ), E10 will give you a safety margin over normal fuel? (providing AFR's are the same).
https://www.sau.com.au/forums/topic/157439-98-e10-tuning/#findComment-2926147
Nice! So if you were running on the edge of detonation boost wise (23psi :happy: ), E10 will give you a safety margin over normal fuel? (providing AFR's are the same).
Yep.
You might need to add a tad more fuel. Only way is to check it
https://www.sau.com.au/forums/topic/157439-98-e10-tuning/#findComment-2926247
So if im tuned for bp98 and i use shell100 i should be ok and still have safe a/f ratio.
DennisRB30, i would assume the extra 2 octane in shell100 will help less knock slightly, how much???
Well yeah. Thats comparing 100 octane to 98 octane so that would be a given. I am talking about 98 octane E10 fuels like boost 98 from United servos.
https://www.sau.com.au/forums/topic/157439-98-e10-tuning/#findComment-2926989
Ethanol does have better anti-knock properties than regular petrol.
RON : 129 - MON : 102
As for tuning, ethanol is 35% oxygene but also contains less energy than regular automotive fuel.
Typical automotive fuel contains around 45 MJ/kg where as ethanol contains only 26 MJ/kg.
This would indicate that, like methanol, a richer a/f mixture would be required to obtain maximum power.
However in blends as low as 10% it's probably not such an issue.
Long story short, yes you can run a bit more timing.
https://www.sau.com.au/forums/topic/157439-98-e10-tuning/#findComment-2927100
  • 6 years later...
Everything I read about "E10" suggests that it's not enough ethanol to get back what you lose consumption/power wise . Most of those people were not talking about 98E10 , mainly the lower octane stuff .
When they say 98E10 I'm curious to know what grade ULP they mix the 10% ethanol with to end up at the 98 oct number . The cynic in me reckons its whatever the cheapest means of making something that engines can burn and be tested to show 98 octane numbers . The best option would be blending straight ethanol with 98 oct PULP but where can you get pure anhydrous ethanol so you can tip 5.5L in yourself ? It's possibly better to work how how much E85 contains 5.5L of ethanol , pour that in a fill up with say BP 98ULP .
A .
https://www.sau.com.au/forums/topic/157439-98-e10-tuning/#findComment-6890049
They should mix just fine in the tank. Id put the ethanol in the tank then the ulp ontop.
I ran 100E10 from united. I got better fuel economy amd my knock which was randomly present in the upper rpm was gone. I will be filling up with that fuel when ever I pass the station.
https://www.sau.com.au/forums/topic/157439-98-e10-tuning/#findComment-6890771
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
