At this point I doubt there's a cheaper deal that the Sard 550cc injectors at you know where.
I was told that Bosch injectors may not be too expensive if you're friendly with a distro.
~$150 odd times six = $900
It's these times where I wish I had an SR20!
Ha ha!
T.
Guest bobchicks
The SARD price does sound very good, but how can they be so much cheaper than the Nismo's?
I'm in the same position T, about to get reg, fuel pump and injectors. I was hoping the PowerFC would be able to handle the upgraded system without increasing fuel consumption though.
Last night I put in 45 litres for 330kms. eek!
Nismo has a better 'name' than Sard (which is a soap and a Supra parts people).
PowerFC should be the best choice. As it is you *may* not need a reg.
Pressure may be fine with the pump only - but a Nismo or even HKS, Apex'i reg. is not too expensive.
My car leans out big time over 1 bar... so it is necessary or all this money was for naught.
T.
Hi guys, Nismo don't make injectors, neither do Sard, they buy them from injector manufacturers, stick them in their boxes and double the price. Nippon Denso is the main injector manufacturer in Japan. Read what it says stamped into the injector body, not what is on the box.
Hope that adds to the discussion.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
