Hey, hows it going.. ok now i have an r33 gts and am having a few problems with my engine..
1st - Ok when i turn the ignition over and the engine starts, a loud clacking, clicking noise occurs for about 2 seconds.. Now am not sure where it was coming from... but i think it might be the starter motor?? does this sound right??
2nd - When my car is idling it sounds like its missing and really slugish.. Now i cleaned me engine bay not long ago and may think that water has got into somewhere it hasn't.. Now wat should i check or replace to stop this from happening?? coils, plugs??
3rd - on my dash the open door light is always on even though every door is shut.. wat should i check ??
thanks, any input would be great..
cheers
https://www.sau.com.au/forums/topic/157476-engine-problems/
A couple people have complained about this and a one suggestion that was put out there was that your timing belt may be slipping when the car starts... Might have to look into replacing it.
Is that when the problem started? If not then it can be heaps of things
your fuses is all i can suggest, short of that your wiring maybe be screweed. If you know anything about wiring, see if you can check all the connections are solid.
https://www.sau.com.au/forums/topic/157476-engine-problems/#findComment-2927892
cheers
Had the same issue, it was basically, the hatch where the lock clicks into was loose and moving around because the bolts holding it in weren't secure, that's located on the wall of your door, looks like a nose ring sort of thing with black padding around it to hold the lock in. If that's worn or faded the lock might not be engaging properly, hence the light is coming on. Also you'll notice that when you close the door, the reason the light comes on and dissapears in the normal case is because it forces a button down, might be an idea to check if that's working properly too by pressing it down manually and looking at your dash. This stuff is all relatively close to each other on the door arm of your car's body ( open your door and look to the left im talking about the part that runs up from where you can rest your feet on the side of your car)
If it's a matter of the black padded material on the metal ring/arch that hold the door locked in place being faded or worn, just wrap some black electric tape around it until it fits snug again or find a replacement for it..
If that isn't the case maybe it's something electrical.
And Don't directly use water on your engine bay.. E.g dont spray it with a hose lol.. hope you didn't. Just a damp cloth or preferably de-greaser or something.
https://www.sau.com.au/forums/topic/157476-engine-problems/#findComment-2931567
you can degrease and then spray off. do it when the motors hot and dont bother startting it for a while. the hot motor will dry the water out quicker. ur engine can get wet, otherwise it would be sealed from the outside world, it rains u know.
its just that it may cause some problems with the electrics. eg. it may bridge a contact in one of the loom connectors etc. or more commonly, provide an easier ground for the spark plugs/coils than firing across the gap.
dont spray the hose straight onto sparkies or coils or dizzys (lol old school) more than you have to and let it all dry a bit before attempting to statrt a wet motor
https://www.sau.com.au/forums/topic/157476-engine-problems/#findComment-2932476
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 馃ぃ馃憤   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
