hey guys
unfortunately i have decided to part with my beloved skyline as it is not financially viable for me to own one at this present time.
It has just under 50 000kms on the clock, and i will not be driving it much during the sale period
The car is located in brisbane
The Price is 25 000 Final price drop
now down to the nitty gritty
i was first owner of car from japan, purchase car from the sponser of this site aussie car compliance
the car has:
sony head unit mp3 player
rear sony front stage 2 ways
front 3ways alpine DDdrive
auto watch immobiliser/alarm with a turbo timer
brand new 19inch koya wheel and tyres, black centre with inox lip not even a month old
from japan came with: Kyb damper adjustable suspension
full 3inch mandrel bent exhaust, 3 months old
short shifter (with it from japan)
Other then that completely Stock, no engine work
if you are interested please contact me here with a private message
or email me directly at
[email protected]
Edited by Jaker34
https://www.sau.com.au/forums/topic/157477-sold/
hey mate
Pictures added, sorry for poor quality they are just a quick job on my phone
no pictures of interior but trust me it is as good as the exterior
there wassnt enuff light for interior pics
anyway as you can see it is immaculate,
Edited by Jaker34
https://www.sau.com.au/forums/topic/157477-sold/#findComment-2931361
Very tight... looks great! the only thing is the colour! ive had 2 white cars in a row an s15 and a soarer n i was adament that i wouldnt make it a 3rd this time round (although white 34's do look hot) neways ill keep lookin but if i dun find what im lookin for i might end up given ya a call
gl wif the sale man
https://www.sau.com.au/forums/topic/157477-sold/#findComment-2936008
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
