I own a R32 GTSt and have found something very interesting with the brakes.
I wanted to change the rotors so ordered in some R32 GTSt disc rotors: A 280mm diameter, 30mm thick disc rotor (for the front). These are the factory spec - and can be found in the DBA catalouge.
When I took the rotors of my factory R32 GTSt I found that the rotors were 280mm diameter, 22mm thick.:(
The 30mm rotors would not fit into the callipers!:)
Is anybody aware of any R32 GTSt’s that came out of the factory with smaller brakes? (280 x 22)
Would normal R32 GTSt callipers and rotors fit on this model?
Would R32 GTR Brembo’s bolt straight on as well?
I would appreciate any assistance, even if only to point my in the correct direction of where to find this information.
https://www.sau.com.au/forums/topic/15749-weird-r32-gtst-factory-brake-options/
I've done a bit more research and it seems that the 4 pot calipers were an optional extra (technically standard on an M spec) - but could still be optioned out.
The single pistoned caliper is the same as a S13 200SX brake.
I checked my model spec KRCR32RGFSM AA - which is defintely a 5 spd manual M spec GTSt (don't know what the AA stands for) - so my only guess it was optioned out - or changed over before it landed in Oz
Means with a bit of modding (ripping off the dust covers) a GTR brake will fit under there nicely.
If anyone hears more about factory options - I'm still interested
Thanks,
Do you have standard rims? Remember the 4 pot's stick out alot more and require different offset rims. If you have aftermarket ones theres no quarantee they will fit.
Just something else to think about if you didnt already have enough. By the way the 4 pots are commonly bolted onto S13 silvias and 180SX's so theres no problems bolting them up. Clearance is the main issue.
Red17
PS: I though the M Spec was HCR32, not KRCR32?
Yeah the type is E-HCR32, where E stands for petrol, and HCR32 is the model type.
I've posted another thread about decrypting the VIN plate (which my other research project - related to determine why I have such pissy brakes)
Might check out the availability of 4 pots on Silvia's - almost all have 4 stud wheels which means the rotors wont go on my 5 stud hubs.
The car if defintely M spec from the model spec, but also it has a std GTSt steering wheel, not the snazzy M spec wheel. So it seems the car is a factory M spec with a couple of downgraded options.
Maybe the original buyer didn't quite have enough money, and had to deoption the car.....maybe I'll never find out.
Thanks for the caliper tip though, I'll let you know what I find out
KRCR32RGFSM AA
RC = rwd, R = M spec, 32 =R32, GF=manual (that's about all that is confirmed at this point)
An offer worth considering.....
Would that full set of GTSt brakes come with a master cylinder as well.
I have a bad feeling if I upgrade my calipers, that I will also have to upgrade my master cylinder.
I will try to work out this week what the part number for the big brake master cylinder is, and if that is what I already have installed in my car.
I've got a hunch though that I will have a much smaller master cylinder (to go with my 180SX size brakes).
Thanks for the offer though Dragan, I wont keep you hanging too long.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
    • Can you covert an R32's AC from r12 to r134 if the compressor/hoses etc are still all good? Pretty sure on my car the AC was degassed when it was imported  to remove the naughty r12 and save the ozone layer, and the fancy climate control system just blew air around. Was happy to drive the car with windows down back then, but now I am old and need to be kept cool
    • Just to circle back here, I've sold my automatic trans to another Stagea owner in OH.
