I own a R32 GTSt and have found something very interesting with the brakes.
I wanted to change the rotors so ordered in some R32 GTSt disc rotors: A 280mm diameter, 30mm thick disc rotor (for the front). These are the factory spec - and can be found in the DBA catalouge.
When I took the rotors of my factory R32 GTSt I found that the rotors were 280mm diameter, 22mm thick.:(
The 30mm rotors would not fit into the callipers!:)
Is anybody aware of any R32 GTSt’s that came out of the factory with smaller brakes? (280 x 22)
Would normal R32 GTSt callipers and rotors fit on this model?
Would R32 GTR Brembo’s bolt straight on as well?
I would appreciate any assistance, even if only to point my in the correct direction of where to find this information.
https://www.sau.com.au/forums/topic/15749-weird-r32-gtst-factory-brake-options/
I've done a bit more research and it seems that the 4 pot calipers were an optional extra (technically standard on an M spec) - but could still be optioned out.
The single pistoned caliper is the same as a S13 200SX brake.
I checked my model spec KRCR32RGFSM AA - which is defintely a 5 spd manual M spec GTSt (don't know what the AA stands for) - so my only guess it was optioned out - or changed over before it landed in Oz
Means with a bit of modding (ripping off the dust covers) a GTR brake will fit under there nicely.
If anyone hears more about factory options - I'm still interested
Thanks,
Do you have standard rims? Remember the 4 pot's stick out alot more and require different offset rims. If you have aftermarket ones theres no quarantee they will fit.
Just something else to think about if you didnt already have enough. By the way the 4 pots are commonly bolted onto S13 silvias and 180SX's so theres no problems bolting them up. Clearance is the main issue.
Red17
PS: I though the M Spec was HCR32, not KRCR32?
Yeah the type is E-HCR32, where E stands for petrol, and HCR32 is the model type.
I've posted another thread about decrypting the VIN plate (which my other research project - related to determine why I have such pissy brakes)
Might check out the availability of 4 pots on Silvia's - almost all have 4 stud wheels which means the rotors wont go on my 5 stud hubs.
The car if defintely M spec from the model spec, but also it has a std GTSt steering wheel, not the snazzy M spec wheel. So it seems the car is a factory M spec with a couple of downgraded options.
Maybe the original buyer didn't quite have enough money, and had to deoption the car.....maybe I'll never find out.
Thanks for the caliper tip though, I'll let you know what I find out
KRCR32RGFSM AA
RC = rwd, R = M spec, 32 =R32, GF=manual (that's about all that is confirmed at this point)
An offer worth considering.....
Would that full set of GTSt brakes come with a master cylinder as well.
I have a bad feeling if I upgrade my calipers, that I will also have to upgrade my master cylinder.
I will try to work out this week what the part number for the big brake master cylinder is, and if that is what I already have installed in my car.
I've got a hunch though that I will have a much smaller master cylinder (to go with my 180SX size brakes).
Thanks for the offer though Dragan, I wont keep you hanging too long.
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
