I bought this car back in 2003 of a guy who imported it, i have since owned the car for 3 years and never had any problems with it. It has been regulary serviced, detailed and looked after.
For about a year it was my regular daily driver, and since then i have started my own business so i have had another car to drive around in. The skyline has been my weekend car but now i am moving onto other things so it is time for it to go.
1993 White R33 GTST (10 Months Rego left)
72,000km
5 Speed Manual
Sunroof (Rare to find)
Climate Control
*ENGINE*
Engine rebuilt less then 10000kms ago
Gearbox rebuilt and brand new clutch 10000kms ago
Front mount intercooler with custom made aluminium piping
K & N Pod filter
3inch Turbo Back exhaust
Aftermarket blow off valve hidden in the front bar, stock is still in original place
*EXTERIOR*
Nismo clear side indicators
Full Mspec bodykit
Mspec front bar cut open to accomodate intercooler
Painted red brake callipers with more then half pads left
18x8.5 and 18x9.5 deep dish starcorp impul wheels with tyres that are less than 5000kms old.
*INTERIOR*
Mainly standard except for autometer boost guage
Nismo 300km/h speedo
JVC headunit with dvd player and screen
sony explode subwoofer and amplifer and pioneer 6 inch speakers
*Many other modifications*
This car has been a dream to own and drive, but i do not have the time to drive it anymore as it is my weekend car. I bought the car 3 years ago stock standard and i have not had any problems with it and it has never let me down. It gets serviced every 5000kms.The car looks clean and not overly modified, but it also has plenty of go.
$16 000 ono. Will swap with something of interest.
Contact me on 0401 004 491 for any other questions or to arrange an inspection.
Thank you
Dave...
post-10608-1172100270.jpgpost-10608-1172100289.jpgpost-10608-1172100306.jpgpost-10608-1172100323.jpg
Edited by MR R33
https://www.sau.com.au/forums/topic/157499-r33-gtst-10-months-rego/
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
