Hi All,
I just install the e11 to my r32 gtr with stock wire. Everything fine except the air-cond set-up.
Whenever I turn-on the a/c rpm will drop 150 rpm. Advise & info please. :)
What version of the Halwin software are you using 1.62 or 1.71?
In version 1.71 I found under Otions: Auxilary Outputs:
In the Auxilary or PWM outputs, there is an option to cut the A/C out above a specific TPS or RPM but haven't found a rev compensation yet.
Edited by AWD2Go
https://www.sau.com.au/forums/topic/157515-haltech-e11v2/#findComment-2928655
have you wired the standard FICD valve to turn on with the a/c compressor, its usually switched via the standard ecu. just wire it to switch with the compressor clutch.
also if you add some timing in the load cell with rpm just below standard idle, it will help reduce the drop because as the rpm tries to fall, it adds more timing and the torque increases and less drop.
going through the ecu via an input is best, but i have done the above with numerous vehicles and the idle doesn't really budge more then 25rpm with the a/c ompressor cycling on idle.
https://www.sau.com.au/forums/topic/157515-haltech-e11v2/#findComment-2931244
  • 3 months later...
