Intercooler Kit Install
Nismo_God
 Share
Hi Guys,
I am looking to buy one of those justjap cooler kits and was thinking that there must be someone on here that knows how to do it, or did it on there own car. I have a S2 96 R33 with stock front bar.
If there is anyone out there who can help me out? I live in Sydney and dont mind driving....
Thanks!!!
Hi Guys,
Thanks!!!
Hey Mate,
Me and a Mate did the same thing, same kit, same car. It's not an easy job.
You will need the tools for it. Angle Grinder is the god tool in this situation. (you will need to trim the front bar)
3" whole saw for the hole to put the piping through.
Also for a side note, forget trimming your Fan back... all we did was make a bracket and forced the piping to lift up a little higher so we didn't hit the fan. (Place it where you connect the pipe's arm that connects to the engine block)
Our biggest problem was that we misscalculated the 3" hole for the pipe.. so yeah.. it's now a bigger hole... ;)
If I'm free any day soon I'll see if I can lend you a hand but it won't be till next week
Well are you prepared to spend half a day fitting it or not?
If you cant, and are not handy with tools, then the $400 is justified for a legit install.
Although ive seen some cheap prices around $250 here in Melb which is damn cheap to install kit
$400 bucks?!?. i thought the workshops usually charge $150-$200 for a fmic install, thats what i remember paying but that was years ago with a workshop.
Hardest Part:
-Cutting the 3" hole in the body/chassis to allow the return intercooler piping
-Trimming the front bar so it looks nice (they did a sh1t job on mine, not even straight)
-Making a custom bracket to keep the piping away from the fan? (does the justjap kit offer something like that already?)
I reckon mate if you got the tools and time DIY otherwise save the hassles and headaches get someone to do it.
my2c
how much off a head ache is the job? is it worth the $400 just jap are charging?
Not worth $400 by far.
It's a doable job, but can get tricky, but I wouldn't pay a professional any more then $250-$300 at least!
I got the same offer from Just Jap..
Anyways, I guess it's just down to if your willing to slice through some of your car.
Hardest Part:
my2c
No custom brackets for the piping to lift it above the fan.. there installation instructions told me to cut the fan back.. Stuff that!!
If they supplied 2 more of the smaller brackets that are ment to mount the intercooler to the front bar it would do the job. So I just copied that idea and made another 2.
what he said.
just ring around a few workshops and get some quotes if you are concerned about the cost
i put mines in my r32 wasnt to hard just get a few mates to lend you a hand. the most time consuming part is getting the hole under the batery tray. and i shaved my fan back a little because the pluming hit when i shut the bonnit.
good luck with it mate
Edited by blck32
Thanks guys, I might have a look at it first to see if i can do it, but uni starting soon so that will cut into my spare time. If not i'll ring around, just wanted to get a feel if $400 was too expensive. Thanks!!
I had a look at mine cause I just bought a cooler kit aswell and I have f*k all room between my fan and engine...I don't understand how my 3" pipe is going to fit??? But option 1 says around $280 to fit it, money well spent when I think they will have fun with my fan to get it to fit.
Mr_G on these forums installs fmic.. hes done a fair few justjap kits..
Hes in sydney as well.. and he comes to you if you close by..
pm him and ask if hes free..
MrG doesn't offer his services anymore. (FMIC installs that is)
The pipe go's over the top of the fan
Hey guys, as you know ive been a FMIC install r33 guru known to the SAU forums.
I dont tend to do as much FMIC now simply because I have a full time job and sometimes just need abit of time to do my own things on my days off.
Im happy to help out fellow SAU'ers if we can organise times that suite us both. If your keen on getting one fitted, just shoot me a PM and we will go from there.
If your within Sydney, ill come to you which saves you the biggest hassles of all. I also charge a flat fee which i gaurantee is a VERY competitive fee for the quality of workmanship. But ill be doing a job this saturday for a fellow SAU'er so ill try and get some photos of my work once im done :)
Jase
 Share
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
