Ok, lets see if I can explain this cleary :) I have just recently upgraded my fuel system again, and since putting in the powerfc injector settings the car wont start. ( R32 GTR RB26 )
The car was running nismo 600cc injectors and now I am running the Sard 800cc twin sprays.
Using the properties for the injectors:
Stock Injectors are 444cc/0.77msec latency
Old Injectors are: 600cc/0.81msec latency
New Injectors are: 800cc/1.10msec latency
The oringinal settings for the 600cc's on the powerfc were:
Injector- 74% (444/600) Latency- +0.04 (0.81-0.77)
that obviosly ran fine....
soooo, first try I put in the settings for the new injectors
Injector- 55% (444/800) and Lantency- +0.33 (1.10-0.77)
...........doesn't start :P
so I thought.... well its tuned for the 600s, so maybe I'll do the injectors corrections for them?
Injector- 75% (600/800) and Latency- +0.29 (1.10-0.81)
...........doesn't start :)
so now I've checked fuel pressure in the rail and going by the manual of 42psi, its all there, holds pressure on purge and cranking...
am I doing the injector corrections right??? The battery is now being recharged from been drained flat from cranking and purging pumps, so I'm trying to find if I'm missing something. :kiss:
Edited by CameronBNR32
https://www.sau.com.au/forums/topic/157522-powerfc-new-injector-settings/
anything odd in SENSOR SW CHECK ?
engine check light come on ?
does the engine start and then stall or wont start?
I did check all the sensors and they were all registering
The engine will sometimes 'puff' but wont get anywhere near idling/starting so all the dash lights are still on.
At the moment I'm pulling out the plugs to see if they are wet and see if any fuel is actually getting in there.
logic says to me it should be;
Old Injectors are: 444cc/0.77msec latency
and then do it based on that, forget that you have 600cs previously
I pulled the plugs out, the injectors were damp, but not as wet as I would expect them to be..
Does anyone know the exact Latency for the Sard 800cc Twin Sprays? I only found one resource that said 1.10msec... couldnt find much info at all. :(
Injector- 74% (444/600) Latency- +0.4 (0.81-0.77)
don't u mean .81-.77=.04 .............maybe double check your input for the 800's
It was 0.04 in the powerfc, just a typo by me :laugh:
thanks
Outta interest, do you guys change your values and the tune is still perfect with the bigger injectors...so WOT whenever or do you take it easy and just use it as a bandaid type fix....ie enough to get you to a tuner to get it sorted properly?
When you change injector sizing, for what ever reason, you will need to have the map touched up to suit as the change in size can affect the fuel delivery slightly at certain loads and RPM. The touch up is a quick affair that would only take an hour at the most. BUT, if you're not fussy, you can get away with no changes whatsoever. Its up to you.
In other areas such as startup fuel and accel pump fuel, these settings are in injector ms times and ARE NOT CHANGED WHEN YOU RESCALE THE INJECTORS !!!!.
That lovely puff of black smoke, even on light throttle changes is the accel pump fuel and with larger injectors like 700CC can be a cloud of black smoke at the lights. The PFC settings for accel pump fuel are around 4.5 to 5ms standard and with larger injectors I have reduced these times to about 1.2 to 1.5ms with no black smoke and perfect throttle response (actually got better the more I reduced it) . Fuel usage also reduced dramatically.
Hope this helps,
Mike
I set my PFC to these settings after installing 600cc injectors and had no luck getting my car to idle at all. Had to take it in for a retune in the end :)
  • 1 month later...
Cameron,
A mate recently dropped a set of Sard 800cc twinsprays in to his setup.
He runs the rb20det pfc on his rb30det and using the technically correct values the thing just would not run.
I played with the values (what they are; I can't remember) until it ran and got the o2 sensor swinging.
The only thing I could think of is the twinsprays some how throw everything out, we didn't check fuel pressure all though once on the dyno all appeared to be good. Perfect cold/warm starts, no drivability issues, excellent fuel economy and expected duty cycle for the power being made.
To this day it still won't run with the technically correct injector size and lag trim.
He also runs a Z32 afm.
I've seen the rb20t pfc do funky things previously when running a non-std afm.
Your problem isn't related but for others in the future. :O
I've just done a basic road tune. injector lag is set to +32, and correction 55%. AFM correction however has been changed so at idle is 50% which quickly changes to 115% after 1.5v on the AFM's.....very strange. I also changed the correction values for voltage standard injectors are .772 @ 14v so I calculated the % change at each voltage and input the values for 1.10msec injectors. I've also halved the accel enrichment which seems to run well. Car runs 1.8bar nicely with very stable AFR and very low knock.....just have to get some more spark...I think my plugs are already at .6mm ...damn it, lol
Quote
"SARD 800cc twin hole
Injector- 55% (444/800) and Lantency- +0.33 (1.10-0.77)"
Are these the correct settings, I have just installed some.
going by the PFC FAQ .77-1.10 = minus .33 ?????
PFC FAQ is wrong,
its definately
New lag time - old lag time. so +.33 for my 800cc 1.10msec
  • 3 weeks later...
Sorry BOOSTD, I havn't been checking back with this thread as I thought it had died.
The injector lag and size value caculation I worked off was in my powerfc user manual.
The settings I have in my car at the moment are:
it starts and runs, but runs rich (I'm not sure the reason to running rich is the setting on the new fuel regulator).
Cubes- RB20 powerfc on a RB30? wouldn't that be the problem :D
I've got to get my tuned asap, hasnt moved since the thread has been made! I need to stop modifing the dam thing!
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
