Autosports "ultimate Control" Skidpan No#1, March 24th Oran Park
  • Replies 136
Sorry Corinne,
Not doing this day - car is going to cop an abusing over long weekend so I want to save it for that.
I'll most likely do the next day of this.
I dont think helmets are required for shid pan days, Its been so long since I did one though!
Jeff what rubber you planning to use?? Your goin to be all over the course with that stuff you got on there now
Edited by Risking
yeah i know :huh: thats half the plan, i havent got enough time to get organised. if i manage to change brake pads before the end of the week i'll be happy enough. unless your offering?
i am going to have to give up my spot because my car is not ready and i had to spend a few hundred $$ on it last weekend so it will put me out if i go..
Thats fair enough..
We make Corrine Run... :(
Oh ha ha.. so not! Car needs some work..
So Corinne - what happens if we dont make the 40, do you know? The day will still run with a smaller field?
Im pretty sure we will just be running a smaller groups then.. It will still go ahead either way..
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
