Smash Repairers
CeJay
 Share
Just got rear ended. Cars still drivable, not too damaged, no broken lights, but the boot doesn't close properly.
Anyone have any recommendations for smash repairers? preferably on the north side? I was thinking of going to Fuller brothers in belco? Anyone been to them?
Canberra Automotive refinishes. They're on lathlain st in belco next to the Carwash. also there's another one up the top on Nettleford st just down from Sportsmand warehouse. I forgert their name, Belconnen Auto refinishes or something.
Thanks for the tips
Sorry wouldn't go anywhere near Canberra Automotive refinishers, last time I went there, had to get it redone, and wasn't really happy with their work. I am going to try Belconnen auto refinishers though.
Thats crap Chris... Try Prestige in Hume very very good they did my sides after some f**ked keys had been run down them.
U must be one of the lucky ones, they did my car when it was side swiped, they buffed it so much that you can see where the paint burnt, they refused to fix it. It wasnt part of the quote, and yes they did it for free, but i wasnt expecting them to ruin the paintwork.
I've ended up going with belconnen auto refinishers, hopefully they do a good job. Getting some other stuff done while its getting fixed.
Let me know how it goes. I got a quote from them for $1500 to respray my front and rear bumpers.... I felt it was a bit of a rip-off but if they do a good job it might be worth it.
Thats steep, it cost me $500 in Darwin for front and back on my (stock) dark metallic blue N15 Pulsar SSS. If it can be done for that cheap in Darwin, then no one has any excuse down here since darwin is 5-10% dearer than anywhere else in oz.
It was something to do with having to buy chrome strips as the ones already on the bumpers can't be removed and replaced? I'm going take the bumpers apart myself soon and just get them repainted without getting charged for R&R
  • 4 weeks later...
Picked up the car on Friday, can't fault them on the work, color match looks to be nearly spot on. I'd use them again, I was disappointed with their customer service though, didn't keep me up to date with delays, but I can live with that. Ended up costing 1000 to fix the rear guard dent, rhd rust patch and fit the new front bar, the rest was payed by the other party.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
