hey guys,
in my quest thisarvo to finally knock the average plug / alternator noise i've been getting through my amp, i think i've made the situation alot worse. as it was the noise was quite loud, enough for me to leave the amp for the rear speakers & sub unplugged.. now the sound is about three times as loud and i'm also getting a humming of a much higher frequency when the motor is off, and the only thing's on are the amp and headunit. I was fidling with the amp positioning and wiring (rear 6.5" run through the amp) when I heard a bit of a pop through the sub which was when the noise got louder, and upon turning off the engine the normal buzzing alternator / plug sound disapeared and was replaced with the much higher freqency sound, definently running alot higher than any of the equipment in the car which leads me to believe that it is the headunit itself.. i swapped out amps to make sure that the RCA earth wasn't shorted out at the amp, and have isolated the sound coming from both RCA plugs (ran an ipod directly to both channels on the amp with the engine running and no noise), so i earthed both ends of both of the RCA cables , which had a negligible effect on the sound. I used the existing wire that runs with both of the RCA cables to earth it, and did not actually splice into the braid on the signal wires themselves.. I'm thinking this wire is there to stop and induced currents that the RCA plugs might pick up along there path to the boot, and probably cured my original prolem, anyway this leads me to believe that i must've somehow shorted the RCA earth at the headunit which is giving me these wicked noises through the amp.. has anybody else got any oppinions or advice on my situation?
cheers and thanks in advance guys,
mark.
:happy:
https://www.sau.com.au/forums/topic/157591-noise-with-a-difference/
Try running other RCA's just on the outside over seats to see if it is the RCA's themselves, if the problem is still there, there is a good chance that the pre-amp in the deck is not healthy, try another deck even an older one that works if you can get your hands on one.
yeah. i believe i've done something to the pre-amp, is there anything else i can do to help short of opening it up and attampting to fix any burnt tracks..? i've heard of running filters but with the range of frequencies i'm getting i feel i would also be filtering out alot of frequencies associated with the music i would like to be listening too :(
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
