Hi I have a quick question in relation to my Yellow Top battery I bought about 12 months ago.
I have a optima deep cycle 41 A/H 500CCA Yelltop battery, I belive its a D51.
I'm using the battery in my 1990 nissan skyline GTR. My problem is this : I was running a mono block amp (sony XM-D1000P5) and a simple two channel amp. The stereo was fine.
Recently the 2 channel amp broke down and I replaced with a 4channel amp. After doing this my stereo now chops / cuts out after 10 ~ 15 minutes of playing at loud volume....
What I mean by chops out is that the mono block amp and sub continue to run along with my head unit but the front and rear fill running off the 4 channel amp chops out (cuts out).
So I bought a 1 farard capacitor to try and fix this problem, but it still occurs. Then I also ran a new 4 guage earth cable in the boot direct to the 1 Farah capacitor and also to the negative side of the battery to try and remedy the problem, still happens.
THE PROBLEM STILL OCCURS.... Also for infomation my mono block amp uses 10.5 ~ 16 Volts and the current drain at rated output 90A (at 2 ohms) and my new sony 4 channel amp (sony MSD46X) and the Current drain is (@ Rated Power - 4Ω): 31Amps. So my question is can the Optima yellow top battery handle my CAR amps or what else do you think the proplem can be....??
PS : Also does anyone know the output of a 1990 R32 GTR alternator?? see if may be a problem aswell?
https://www.sau.com.au/forums/topic/157606-amp-cutting-out/
dont think it has to do with alternator or not having a capacitor..i run 12 speakers in my car not including my 2 subs..i hav two monoblocks, one for each sub..and i just have a exedy heavy duty battery..nothing flash..
i had a similar problem to what your describing when i 1st started doing up my sound system..this could be one of two things..
1) over heating..the amp is over heating..and so going into protection..
2) amp is broken..i had an amp..dat worked..but..afta few mins of operations..turns off..
frm memory..mono blocks hav very good heatsinks..and can handle heaps for long periods of time..whereas 4 chan/2chan's cannot..
connect a mates amp or sumtin..and see if it doesnt..then its ur amp..get a new one..if it still happens..go get it chkd out at an car audio store.. unless sum1 else can provide you with some other info..
cheers
https://www.sau.com.au/forums/topic/157606-amp-cutting-out/#findComment-2926916
Thanks for that sugestion. The sony 4 channel amp is brand new and I already swapped it for a new one it it didn't correct the problem.... Hense this is why I'm stuck between a rock and a hard place. The amp did get hot though and that was both amps....
What causes amps to get hot? I already run a 1 farad cap to assit any voltage peaks etc...
https://www.sau.com.au/forums/topic/157606-amp-cutting-out/#findComment-2927084
output transitors control the amount of current frm the pwr supply and get hot..these are usually connected to the heatsink..
what a mate of mine did was, connect a couple PC fans around the amp..they cost f all..and easy to wire up..
also i suggest, double check all the wiring..i mean everything...rca's frm headunit back..power, ground, rem..everything..
https://www.sau.com.au/forums/topic/157606-amp-cutting-out/#findComment-2929969
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
