Hey guys i wanted to know what are the best 2.8l stroker kits. The two that i can see are the HKS step I, II and III and the Tomei 2.8. How high can they rev too and which one do you guys recommend?
Second who has used the HKS V-Cam System? Is it a worthy upgrade? If you guys dont know what im talking about click on the link below.
http://www.nengun.com/hks/v-cam-system-step-1-a-b
  • Replies 55
Is it correct that the v cam was pretty much designed for larger turbos that did not have response?
and that its now kinda outdated as some of the new single turbos have much better response than what they did back when v-cam was made avaliable?
trying to work out what stroker kit to go for myself, my tuner has suggested JUN but it seems the tomie and HKS kits would also be suitable
I have an early rb26dett, would I be better off starting with a later block from an r33 or r34?
There were two factory r34 gtrs that came out with the v-cam, I seen this in a dvd but i cant remember which one.. I think one of them had a big turbo on maybe a t04z I cant remember.
I remember them saying it was a new break through for future enthusiasts or somewhere along those lines it would be good to hear more about it.
ok. firstly there are no factory nissan RB26s with a v-cam system of any type.
Not many guys in aus are running the HKS or tomei 2.8s. There are a few though. No-one as far as I know is running the HKS v-cam set-up in aus.
I've been lucky enough to go for a ride in a couple of 2.8 litre GTRs in japan, and one that was HKS 2.8 and HKS V-cam. It was a very, very nice set-up. but v-cam and 2.8 stroker are just a couple of parts. they do not necissarily a good set-up make. you need to look at a lot of things (like budget, what you want from the engine etc, what the car is used for) before buying them.
V-cam definately made a difference on this car. It runs a large single turbo and goes 300kph+... but this car was a top shelf effort. no expense spared. on any build V-cam would be one of the last things I'd look at. it's quite a high cost for the gain it gives.
andrew: no it's not outdated. it was only finished in 2005! it's designed for current generation turbos, not old ones.
rathur than start a new topic and without highjacking this thread to much, I was also wondering what advantages and disadvantages there are with twin or single turbos on a stroker engine?
I'd kind of like to keep my twin turbo setup, but a big single may be a more straitforward way to go on a all new and fresh stroker engine?
Okay i know the stage III HKS 2.8L Stroker kit can rev supposedly to 12,000rpm (of coure if the head is prepped to handle it) What about the Tomei kit. I wanna rev to 9.5-10k. I want a big single turbo. Basically i want a highway monster but i dont want something that will lag retardley. I want something that can also handle since i will be taking this car to the tracks. I think a TO4Z with the 1.00 A/R or the GT3582R is what im looking at.
If you want a monster go for a 2nd T04Z...1000bhp! other wise a step 3 is a waste. As BB said there are a few guys running stroker combos. I suggest you search the users "cruiseliner" and "Gav". Coincidentally both from W.A. cruiseliner has a 2.7 Jun with a T04Z and Gav has a 2.8 HKS with twin GT-RS. Good luck with this
if your that keen for the hks 2.8lt kit and the v-cam why not buy the best motoring dvd featuring the hks R34 fitted with these parts and a T04z(think) turbo?
ps a "highway monster" is going to be "laggy" no 2 ways about it
Edited by 1400r
that doesnt really tell you a great deal. other than the car is more resposive down low around the track with vcam on.
unless you listen in japaneseseseses there may be some hidden message
oh i was thinking that newer larger singles were becomming more resposive maybe i been smoking a little too much crack
Pretty hard to answer such general questions without some idea of what are you going to put this engine in and what you are going to use it for. Lastly what sort of budget you are allocating, not just the engine but ALL of the other stuff necessary to make it worthwhile.
:) cheers :)
what about the tomei 2.8l stroker kit, how much can hp can it withstand? how high can it rev?
Dude be serious your not going to tell me your going to rev a street engine to 12K! Do the reading and have a reasonable plan and people will help, otherwise its just looking like your bored and want to have a chat...here it is in one sentence-HKS 2.8 step 2, N1 block, Jun oil pump, t04z .81 .
Reality check this thread please. :)
