  • Replies 47
I know you said you wanted to be different... but WHY? What is the point of hacking up a perfectly engineered car like the 350Z?
There has been so much engineering gone into the 350Z with little details like CF drive shaft and you want to rip it all apart??
  Shabib67 said:
Also to the guy that said the RB might make the handling of the 350z worse is incorrect unless you have factual evidence or data to back that claim up.
weight. Clear and simple. It can be compensated for, but the handling won't be as good as if didn't have the extra kilos.
Anyway, I am curious - do you want the engine or the drivetrain MORE?
My 2c - from where I'm sitting, the murano package makes much more sense on paper. Should be easier to adapt, lighter engine, still 4wd, and cheaper.
Of course, if your heart is set on it... (like I have an R32 because thats what I wanted, despite being 2L with slow 4wd), achieve the dream.
Yeah. Long day at work.
  Shabib67 said:
Also to the guy that said the RB might make the handling of the 350z worse is incorrect unless you have factual evidence or data to back that claim up. The zele car had a very neutral feeling and the drivers that test it said they hoped the new GT-R had the same handling.
Yeah, that'd be me. I'd be incorrect because hanging a longer and heavier engine/diff/shafts etc over the front wheels that could weigh 30 to 100 kilos more than original (double and some for pounds champ) will have no effect on the handling...... Yep, I'd be wrong.
Edited by Marlin
I think it has been done many times before.
In fact just before the gtr35 launch top-secret had one to stick the finger up to Nissan.
They also slapped the 3.5 350Z Motor into a gtr with Turbo's
Shabs....you need to look at what you are after first...before you experiment with the
thought of it. :D
Or on the other hand get some custom panels to make a gtr look like a 350z :P
Sure this is cheaper
The data is in the physics.
Replacing a compact all aluminium V6 with a long cast iron inline 6 pushes your centre of gravity forward. The 350Z already has a front biased chassis, so your car will be even more nose heavy. What do they say about the handling of front heavy cars again....?
The VQ35DE already sits half way between the strut towers, so the RB26 is going to have the vast majority of its mugh higher weight in front of your axle line. And that's before we include the weight of the intercooler, radiator front driveshafts, front LSD, etc which you've had to push forward to fit in front of this engine. There goes your polar moment of inertia.
Then there's the suspension, which has also been engineered with a specific weight balance in mind and you've just gone and f**ked about it. Its not just the spring and damper rates - the entire geometry will no longer suit. There goes your handling.
You keep crapping on about the Zele car. That was built for rallying, by a big engineering house with connections to Nissan and Nismo engineers in Japan. You've got a couple of apprentice wrench monkeys from a dealership on your side, and we all know how......qualified.....your average dealership mechanic is when it comes to working outside the company three-ring binder.
The Zele car is going to want to oversteer, because that's how they design rally cars to work. And with a surfeit of power, its not difficult to get it to power over. In the BMI video, it was quite taily, especially under power. And since Zele has Nissan factory support, they'd have access to guys who could reprogram the ATTESSA processor and calibrate it for the different weight and distribution of the new car.
And, to be quite honest, BMI isn't the be-all and end-all of technical knowledge. If you have a look at their various battles, they'll line up stock cars in multiple races and get multiple results. In some cases you can tell that they're "pulling" faster cars back, especially if the edition in question is about that vehicle.
I remember seeing one Tsukuba battle where the Supra TT beat the NSX, R33 GT-R, FD3S, etc. Another video, the NSX comes out on top. Of course, the GT-R can nevar lose in another vid. All on the same track, all dead stock.
If you're building a car for Hot Import Nights or some other car show, just import a GT-R wreck and use a big mallet to make the stuff fit. Of course it won't run, but when you've got the car raised up on a plinth so everyone can see your AWD driveshafts and the bonnet raised so they can see your chromed engine cover, everyone will know you're hectic. You could just connect the rear wheels up to the engine, so you can win the dyno comp "in RWD mode, for less drivetrain loss", and you'd have the perfect "different" dyno queen show pony.
The G35x (which we don't get in Australia so few people here know about it) would be even easier still.
Its a V35 sedan (so same platform as the Z33, making transplanting a lot easier), but the engine is mounted longtitudinally like in the Z33 and has ATTESSA ET-S.
Its a shame I can't find the flash video of when the V35 came out on the Infiniti site. They show the different modes it works in. Off the line it uses a 25:75 F:R split for maximum traction, which shifts to 0:100 when cruising. In "winter mode", the power split is 50:50 off the line. The system, like the GT-R's ATTESSA, is also dynamic. It'll shift power front and rear depending on the grip, so it'll turn-in, power out, and hitting loose surfaces like feel like the GT-Rs we're accustomed to.
If I had big budget, I'd import a G35x and rip out its drivetrain for my Z33. I'd twin turbocharge the engine if it would physically fit, but otherwise I figure a VQ40DE out of a Pathfinder being inducted by a Stillen Roots-type supercharger would give me plenty of get up and go.
  `nigno said:
There are some subtle differences int he setup, im pretty sure the sump bolt pattern and everything else would be the same. Meaning the tranny n shit would more than likely bolt straight onto a VQ35DE in a 350z... mating it up to an RB26 is gonna be another thing entirely.
http://www.conceptcarz.com/vehicle/z10606/...no/default.aspx
http://www.conceptcarz.com/vehicle/z8321/N...0Z/default.aspx
^^^ 350z specs as opposed to the Murano... seem pretty similar to me.
Confirmed by wiki, same engine used in all the models specified some minor differences between the two, majority of parts are interchangeable :(
hmm... interesting.
thing with the subtle differences though, will lets say a murano VQ be as rev happy as one from a 350?
i would expect the murano VQ to be torquier since it'd be used as a tow vehicle/commuter. rather than a GT car.
or no?
  Eug said:
hmm... interesting.
or no?
I dunno in terms of "specs" if thats the case, but having driven one, they are much the same as the Ford Territory VS the BA Falcon. Same engine, different car, almost identical feel.
Im looking at buying a 350z Track Edition as my next car, have test driven a few, and the guy next door has a Murano. Same sporty feel as the 350z obvioulsy in a much sort of bulkier car but its still very sporty and nippy if that makes sense. Same deal with the Territory and BA... seems like most manufacturers are going for that kind of combo these days, smaller AWD/4WD cars that feel the same to drive as normal commuters.
  Shabib67 said:
Now to make it AWD easily, cheaply and hassle free thats the million dollar question.
i spotted some grammatical errors there, should read:
free hassle? try cheaply, the million dollar conversion. easy! :laugh:
There project was completed in Oz here that is similar but the conversion was to a VL Commodore. So i dont think it will be that hard. Will be alot of mix-and-matching but once its all sorted. .. What a beast! :laugh: good luck with the project.
-Dale
yeah but theres more room around/in/under a VL, and the VL also would have more genetically in common with a skyline than a 350Z, ie: bolting up the engine and bits of the driveline would be very easy
I have fitted several different engines to the z33. Ive done the VQ40 from the pathfinder and also the 35th engine into my own maxima.
I have also done the RB26 into the Z33. Whilst getting the engine in is no big task getting it to work with the Z33 chassis and body systems is a nightmare. The vehicle I did now has fully opperational VDC with the RB26 and the CAN bus opperated perfectly besides the ECM section. The suspension needed a complete revamp as the entire car felt soggy on the track and was struggling to lap wakefield in 1.15's.
It now laps all day everyday in 1.06's and is pleasent to drive.
With the Attessa system being interfaced into the Z car you will be needing the entire ABS system from the GTR and ALOT of knowledge about the system. Your buddy may know how to fabricate but thats honestly the least of your problems come time to get it working properly.
In all honesty work with what you have OR buy a GTR. The end result will be so much better to drive.
  silverbulletR33 said:
There project was completed in Oz here that is similar but the conversion was to a VL Commodore. So i dont think it will be that hard. Will be alot of mix-and-matching but once its all sorted. .. What a beast! :D good luck with the project.
-Dale
... and that was completed by a very experienced engineering shop, and I recall reading that over 3000 man hours were required. (And a VL would likely be one of the easier vehicles to transplant)
That's a long time if you're doing it part-time :P
has everyone forgot abuot the top secret tt kit for 350z ??
300kw on 8psi which retains stock eng? man if you need awd I have NFI about hte murano but if its already designed for the vq go with that, bigger, newer tech mottor THAT ALREADY FITS and you get a VERY unique car that would probably handle a few high rpm luanches depending on murano drive train. You could probably use aftermarket items since your money pit seems bottomless anyways.
300kw's on 8psi with good tune on stock internals isnt something to sneeze @. admitedly the turbs in the front quaters doesnt look very practical for an every day street application but this doesnt sound like its much of streeter to begin with. talk about your cold air intakes though eh.
Ill have to find the mag I got this out of... prolly something real reputable like HPI or something... all i can remember was the turbo placement was ablsolute shit house but the 8psi @ 300 RWKW was something i didnt forget.
il post back latz with it if i remember
As all can tell...asks the questions and is no-where to be found :P .
I would love to drop the Q45 motor into my XTrail .Now this would be fun..does anyone know if it will fit. :P
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
