The Q45 wount physically fit into the T30. The VQ35 on the other hand. Murano version will line up very well. I have looked over the wiring involved and its not to difficult depending what series T30 you have.
  • Replies 47
SEEING THAT THIS THREAD IS NOT GOING ANYWHERE....
I want one with a Turbo....is this possible...?
2003 late.....The drive train seems to be good...
I havent built a Turbo QR25 but I have seen it done, afar more common conversion is the SR20VE.
It must be at low boost then yeah...Or does the motor have low compression to start off with?
It sounds like a good upgrade...lower the thing and put some gtr rims on...sure it will be bling with the power.. :wave:
Im not sure what it was running finished, I only had a hand in the turbo selection which was a humble S15 T28.
They should handle the regular 8-10 psi with a well tunned ECU.
Design wise the bottom end is brilliant untill you get to the ridiculos balancing ideas
check this link for a crazy ozzie guy who has done a ta22 celica with a lexus 1uzfe turbo conversion and using full gtr driveline to make it 4wd :)
have a read its a huge huge project but would be awesome once finished.
http://www.toymods.net/forums/showthread.php?t=18227
thats gotta be one of the most insane projects ive ever read in my life, awesome piece of engineering work.
dont say anything is impossible after seeing that :laugh:
How bout you buy a complete GTR, and remove the whole chassis from under the body, unpicking the thousands of spot welds, so youre left with the complete drivetrain inc suspension.
Do the same to the Z and simply slide it under and reweld! Sure it might be different in trackwidth and length (no idea about that), but that can be taken care of with a quick cut and shut and some wheel offset.
Easy!
.....easier than making ATTESA fit into the Z chassis.
Forget using a Murano drivetrain. While its probably slightly better suited than an R3x GT-R's, it won't be by much.
For starters the engine mounted is the wrong way, and it only comes with a CVT transmission which are known to not handle that much torque. Almost doubling your horsepower without increasing your redline means you're adding almost double the torque, and that's probably going to munch a CVT.
Actually, if you want a manual AWD Nissan you're going to have to use a GT-R. I can't find a current manual AWD Nissan on the market.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
