  • Replies 75
Posted Images
i had access to an airstip (before it was closed down) and got up to 6500rpm in 5th gear in my 33. thats somewhere around 230-240kmh.
i think it would be safe to say that anyone that has run down the 1/4 mile should've got to atleast about 160kmh.
cept for scorp32 - he has reached 11ty billion!
now THATS moving!
I once had mine on a airstrip and got 240kph, still had about 500 rpm to redline as well from memory, but i ran out of space, was surprised by how good the car still felt at that speed and amused by how close the speedo was to hitting 0 again, although it was very well made road i suppose
Oh nooooooooo ! Not he Flux Capasiter again. . . . .Im getting that twitch in my eye.....Help me Im going.. going....
Cant..... Stop....My....Mind.... %&$#..............
WELL my cars sooo fast that now Ive retro fitted a Kryton switch to my Flux Capasiter, it warps my line into the Lamba Dimension (which is only 1.5km across) and I only have to move about a meter and Im doin like 7 hundred thousand mlies an hour ! ! !
i did that on my push bike, but since this was about skylines i didn't want to brag.
Hahaha, that's hilarious. Once, I went really fast on my bike as a kid, and I nearly shat myself. I seirously thought I was going to die.
It was a massive hill, and I was going 80 ks on my little speedo thing. It was actually pretty accurate (tested next to mum's car).
I was too scared to hit the brakes in case if I unsettled the bike. If I fell off, I woulda been skinned alive.
Even the little bumps on the road almost made the bike lose control. Stupid times. lol
yeah mine cuts out what looks like 190
since i knew about the 180 limiters i thought the speedo was way out but ive been told that the speedlimiters aren't at exactly 180. haven't had the GPS in the car yet but i think the speedo is quite accurate
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
