Upgrade, yes or no?
76 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
And for my next trick. The clutch...
My clutch is slipping a bit now and my recent drag trip wasn't the best. I want to know what you think is the best option for me, not just for the clutch but for the extra parts to make my car good for street, drag and track.
Now, I am expecting everyone to jump in the poll replys with "Jim Berry clutch" over the "Nismo Super Coppermix Twin" or other. I would like to know if other options (such as fork pivot ball, HD clutch pedal, master/slave cylinders) are recommended or even necessary upgrades as well.
I am sort of leaning towards getting the Fork Pivot Ball and HD Clutch Pedal from Kudos Motorsport. Would a new Master and Slave cylinder be a good thing to replace at this stage as well? my GTR is a late '93 model...
I will get the flywheel upgraded as well. If I go with the Nismo single plate clutch the Nismo flywheel can bee added as well, but the twin would support it so a JUN flywheel might be the way to go there and with the Jim Berry single plate clutch as well
https://www.sau.com.au/forums/topic/157719-daily-r32-gtr-clutch-options/
ive got a os giken twin which i have not yet used? id imagine it will be quiet heavy
but when it dies as its 2nd hand ill prob got the full monty jb as i read alot of good things about the clutches?
i havent been on a nismo coppermix. but i would strongly steer away from any tripple plate.
im running a nismo g-max spec 3. solid centre tripple. 1000ps over..
its an absolute pain in the arse.
i used to run witha os giken twin. it was very nice.
JB makes great gear and like everything you get what you pay for.
He has a really good HD single plate that is designed for road/drag that is pretty soft on the pedal which could be an option for you.
The GIKEN twin are great (previously had on in my GTS-t) although it is a little savage with daily driving through town and can take a little getting used too.
As Dave said the g-max are a pain on the roads but i guess it depends on how much you drive the car on a day to day basis and how many times a year you are going to freaquent the strip!!!
As for changing your Master and slave, if there not leaking and nothing wrong i wouldn't worry about them if you are working on a budget :happy:
If you are thinking of hitting the strip a little more then you will gain some pedal feel with the new upgraded cyclinder but its a little overkill for what you have in mind at the moment...
Do you have a budget you want to stick to or money no object as there are some other great clutches out there that would accomodate what you want and more :(
GMB
I drive the car approx. 40km per day to work and back through peak hour traffic and will be seeing the stripe maybe 2-3 times per year as well as the track 3-4 times a year. So I definately want it to last and not be useful for 1 or 2 runs down the stripe and then start smelling and slipping loads more.
people saying "os twin was ok" etc need to be a little more specific. OS make a few different twins for GTR and the thing I have found make a massive difference is whether or not it has the sprung centre, or a solid centre. I have had in my GTR an OS tripple (solid centre) and an OS twin (solid centre) neither of them I would reccomend for daily use. in fact I wouldn't reccomend a 32 GTR at all for daily use. but if you did want a twin the OS sprung centre twins are not bad to drive with.
one more thing. I find these threads are usually a waste of time. the number of plates doesn't have all that much impact on how the car drives. the main factors are:
pressure plate clamping load
sprung or solid centre
type of plates (full face, puck style, buttons of friction material?)
type of friction material used (carbon, ceramic, high metal content, composite...)
the numer of plates is the last thing to influence the clutch behaviour.
What flywheel would be recommended for use with a Twin Plate clutch?
I notice that NISMO make a flywheel that is specific for Single Plate clutches. Do any other flywheel makers make different ones for the amount of plates in the clutch?
I know Perfect Run sell a JUN flywheel, any good?
every twin plate clutch kit i've seen comes with the flywheel. reason being the cage needs to be affixed to the flywheel, so it comes as a kit: flywheel (with cage), plates, intermediate plate, pressure plate + cover, and sometimes bearing too.
If you want a tough clutch thats perfect for street driving, I would suggest the Nismo Super Coppermix twin plate
I have had one in my R33 GTR for a couple of years now and its been nothing short of fastastic.
Excellent and not overly heavy pedal feel, heaps of bite.
Oh, come to think of it I never even noticed the flywheel in this picture (click the clutch first)
http://www.perfectrun.com.au/performance%2...ppermixTwin.htm
Thanks BB and B, I have always swayed towards this over the JB. The Nismo HD clutch pedal will help with that heavy feeling a bit as well.
No offence intended here but if you can't drive or don't like the feel of race clutch get Jim Berry!
I have driven a number of cars with after market clutches from single to quad plates. I have an OS triple and I thought it was easy to drive on the street until it was worn and JB rebuilt the clutch. It just feel like a standard clutch. It's so easy and boring to drive WITHOUT any slip. JB is good :laugh:
I have not driven any of the nismo clutches so I can't vote lol
  • 4 months later...
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
