Upgrade, yes or no?
76 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
And for my next trick. The clutch...
My clutch is slipping a bit now and my recent drag trip wasn't the best. I want to know what you think is the best option for me, not just for the clutch but for the extra parts to make my car good for street, drag and track.
Now, I am expecting everyone to jump in the poll replys with "Jim Berry clutch" over the "Nismo Super Coppermix Twin" or other. I would like to know if other options (such as fork pivot ball, HD clutch pedal, master/slave cylinders) are recommended or even necessary upgrades as well.
I am sort of leaning towards getting the Fork Pivot Ball and HD Clutch Pedal from Kudos Motorsport. Would a new Master and Slave cylinder be a good thing to replace at this stage as well? my GTR is a late '93 model...
I will get the flywheel upgraded as well. If I go with the Nismo single plate clutch the Nismo flywheel can bee added as well, but the twin would support it so a JUN flywheel might be the way to go there and with the Jim Berry single plate clutch as well
https://www.sau.com.au/forums/topic/157719-daily-r32-gtr-clutch-options/
ive got a os giken twin which i have not yet used? id imagine it will be quiet heavy
but when it dies as its 2nd hand ill prob got the full monty jb as i read alot of good things about the clutches?
i havent been on a nismo coppermix. but i would strongly steer away from any tripple plate.
im running a nismo g-max spec 3. solid centre tripple. 1000ps over..
its an absolute pain in the arse.
i used to run witha os giken twin. it was very nice.
JB makes great gear and like everything you get what you pay for.
He has a really good HD single plate that is designed for road/drag that is pretty soft on the pedal which could be an option for you.
The GIKEN twin are great (previously had on in my GTS-t) although it is a little savage with daily driving through town and can take a little getting used too.
As Dave said the g-max are a pain on the roads but i guess it depends on how much you drive the car on a day to day basis and how many times a year you are going to freaquent the strip!!!
As for changing your Master and slave, if there not leaking and nothing wrong i wouldn't worry about them if you are working on a budget :happy:
If you are thinking of hitting the strip a little more then you will gain some pedal feel with the new upgraded cyclinder but its a little overkill for what you have in mind at the moment...
Do you have a budget you want to stick to or money no object as there are some other great clutches out there that would accomodate what you want and more :(
GMB
I drive the car approx. 40km per day to work and back through peak hour traffic and will be seeing the stripe maybe 2-3 times per year as well as the track 3-4 times a year. So I definately want it to last and not be useful for 1 or 2 runs down the stripe and then start smelling and slipping loads more.
people saying "os twin was ok" etc need to be a little more specific. OS make a few different twins for GTR and the thing I have found make a massive difference is whether or not it has the sprung centre, or a solid centre. I have had in my GTR an OS tripple (solid centre) and an OS twin (solid centre) neither of them I would reccomend for daily use. in fact I wouldn't reccomend a 32 GTR at all for daily use. but if you did want a twin the OS sprung centre twins are not bad to drive with.
one more thing. I find these threads are usually a waste of time. the number of plates doesn't have all that much impact on how the car drives. the main factors are:
pressure plate clamping load
sprung or solid centre
type of plates (full face, puck style, buttons of friction material?)
type of friction material used (carbon, ceramic, high metal content, composite...)
the numer of plates is the last thing to influence the clutch behaviour.
What flywheel would be recommended for use with a Twin Plate clutch?
I notice that NISMO make a flywheel that is specific for Single Plate clutches. Do any other flywheel makers make different ones for the amount of plates in the clutch?
I know Perfect Run sell a JUN flywheel, any good?
every twin plate clutch kit i've seen comes with the flywheel. reason being the cage needs to be affixed to the flywheel, so it comes as a kit: flywheel (with cage), plates, intermediate plate, pressure plate + cover, and sometimes bearing too.
If you want a tough clutch thats perfect for street driving, I would suggest the Nismo Super Coppermix twin plate
I have had one in my R33 GTR for a couple of years now and its been nothing short of fastastic.
Excellent and not overly heavy pedal feel, heaps of bite.
Oh, come to think of it I never even noticed the flywheel in this picture (click the clutch first)
http://www.perfectrun.com.au/performance%2...ppermixTwin.htm
Thanks BB and B, I have always swayed towards this over the JB. The Nismo HD clutch pedal will help with that heavy feeling a bit as well.
No offence intended here but if you can't drive or don't like the feel of race clutch get Jim Berry!
I have driven a number of cars with after market clutches from single to quad plates. I have an OS triple and I thought it was easy to drive on the street until it was worn and JB rebuilt the clutch. It just feel like a standard clutch. It's so easy and boring to drive WITHOUT any slip. JB is good :laugh:
I have not driven any of the nismo clutches so I can't vote lol
  • 4 months later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
