Should I move to Newcastle?
18 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi all,
I have been given a really good job offer in Newcastle, and i am sreiously thinking about taking it. Just asking for peoples opinions, or if anyone has done this before and can give me some tips.
Thanks,
Ben
https://www.sau.com.au/forums/topic/157731-decisions-decisions/
pay packet? any incentives..? newcastle that means u support the blues..
will be well compensated, just prefer not to let the world know crap the pay is. Why would i support the auckland blues, when i already have the crusaders as my team.
Just to get you thinking if you haven't already thought of it. A company car these days is worth a good $10k plus a year... tax free to you... Is that pay double before or after tax? Because as you would know, before tax its far from actually being double :) (and without trying to have a go, you know you can nail doing the job? because 3month probations can hurt you... just something to think about)
That and well, you wont know anyone down there, so any money you make you will save, or spend on piss and become an alco... Also its a tops skim spot, so you could get really fit skimming, and Id come visit from time to time because its a tops skim spot.
Guess the thing is, is the money worth it. Thats only something you can decide on.
awesome dude..thts a pretty big step up! I can just call u directly next time i'm hiring a car :)
Thx btw for saving me heaps on the last hire! All up to you in the end to weigh up the pros n cons...if the $$ is worth it I say go for it!
im pretty sweet with that side of things man, ive managed a small business before and learnt alot from that, also mum is senior managment in the company, thats part of reason i have been handed it.
So you're a Kiwi... you can live in Newcastle, anything over this side of the ditch is a step up! :)
Jokes aside, it's not a bad place. I've had a few friend live there for 2/3yrs and all had a good time. good luck!
Haha no worries man. As I said didnt mean any offence by it (kind of cant come out any other way tho!) just I've seen recently a few people get offered these positions, they know they cant do it but they say yes anyway, and 3 months later they have no job, not even the one they started out with.
If you can do it man, and live out of qld (thats the hard bit) Id say go for it. That and the experience would be tops. Do it for 3 years or so, make a mint (that means selling the gtr otherwise you will just have a fast car and nothing else :() then come back, only realise even tho you have $300k saved up it still not enough for a house deposit!
I say NO just from my experience i was in the same boat.
In the same industry offerred more money and better conditions.
But it never happened promises promises and its to late once you have moved.
Very costly experience.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
