If you have a Hks cast low mount manifold I want to know what wastegate you are using and how did you mount it?
I was thinking of going with the Hks std 40mm, but they want +$700 for a new one [and $400 for a questionable quality s/h one] and a tial/turbosmart costs $400.
But other wastegates don't mount up like the Hks one would. I was thinking of chopping up a bit of 10-13mm plate for the manifold and then centreing a 40mm hole and tapping thread into mounting holes either side, but I'm not sure of airflow to and through the wastegate. It would be cheaper [bit of frigging around for me, but I work cheap on my car], but it could impact on performance?
Has anyone else done anything similar?
Another solution is the plethoria of chinese? copies of the hks unit that are on ebay and/or Just Jap/option1garage/driftbits etc etc - I think I will stay away - but has anybody had any experience with them? Usually dubbed the Hks style!
https://www.sau.com.au/forums/topic/157742-hks-low-mount-cast-manifold/
Have used the hks ebay cheapiec without any drama for over a year on a mates car, ive got an hks on on my cast lowmount gtr manifold, and the wastegate is the same as the cheapies, but there is a cast "adapter" piece between the two.This piece mounts the gate on an angle. Should be able to make one with two flanges and a bit of steam pipe bend.
Adriano, why does it have to be at an angle, is this to clear the twin turbo set up of a GTR?
I thought [probably wrongly] that with the adaptor plate supplied with the Hks/JJR type unit that it would bolt straight on [for a single turbo gtst]. Interesting. I will have scour the web for some pics of the adaptor etc.
Anyone using something other than a Hks or Hks style?
The RB20/25 style ones bolt straight up to the manifold with the 5mm spacer/piston seat in between.
I'll get a pic for you later on of mine when i get home from work.
Sorry, the heat shield makes it a bit difficult to make out.
As you can see though, there's a heap of space if you do decide to make an adapter to fit another type of gate.
If you raise it though it would be worth angling the gate towards the back of the car to make it easier to get a pipe off it
Edited by BHDave
Thanks BHDave, you know, I've cruised the net ad nausem looking for a Hks std 40mm unit, but they are hard to come by and when you do, very expensive [compared to other makes]. They have the reputation of being an excellent product, but so do Tial and Turbosmart etc. So I'm just assessing my options and checking how far my project $$$ will stretch.
Thanks for the pics as well, very helpful.
Thanks Dave , any pics welcome . Is that heat shield material easy to get and effective ?
Cheers Adrian .
I picked it up at supercheap one day when i was wandering around the isles trying to remember what i went there to get.
It's acl race, GTRxxx part number. It's actually in a head gasket packet. It seems to do the job, It's noticably cooler under the bonnet when lifting the hood after a drive. The exhaust pipes were wrapped at the same time though.
And none of the rubber hoses have melted yet :(
Im going a Tial 38mm Gate.
I figure make up a flange for the HKS side of things then roughly a 2" dia pipe to a flange for the tial gate should do the trick, it will still be mega close to the collector compared to other manifolds and then I can mount the wastegate where I want cous I can bend up the pipe however I want it. I will probably use stainless also as my exhaust will be stainless also, so why not keep the theme.
-Jez
Hey mate i mounted up a 44mm Tial gate pretty easy hour or so on the tig made up a flange with a short bit of pipe to the v band clamp just gotta be careful of the height cos theres not much room in there, also got one of those hks gates in the back room only problem is the diaphram is shagged if ya can source a new diaphram ill let it go fairly cheap its got a dump pipe and all the flanges
Cheers Andrew
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
    • Hi. Yeah i think that DIS-008 should be ok too but i rather asked. The R8 coils are "sadly" no go for me cuz every solution is for forward plenum. The coils are too tall and one of the(4/5 DK) would not fit under stock J-pipe. And being this NA RB20 i dont even know where to get some forward plenum.(and of course i would need other stuff like custom AFM/ECU etc) and that is kinda non sense for NA without boost. I just looking for solutions for my case 🙂  I try look into those Yaris/Corolla ones.
    • Damn it, no, I topped up before I got to yours I really should look at Costco locations more when I'm out and about burning through fuel
    • Did you hit the one 5 minutes down the road from my place before heading back south? 😛
    • Costco uses Mobile as a supplier, I always get Costco 98 when I'm near one, they are typically about 30 cents or more cheaper than the local Mobile
