Hi all , hearing good things about the T3 flanged split pulsed turbine housing ATP sells as an option for GT3071R turbos . In the US some work is being done on larger A/R versions of this housing that should better suit the GT3076R type turbos . The aim is to have better response with less exhaust restriction so should have more torque at lower revs and boost pressure . The down side is that it means external wastegates with two being better than one .
I'm trying to find out more about the larger ratio housings which sound like .82 and 1.06 , ATP's is .78 so not really enough for a GT3076R to pulse properly and not choke up . Also will look around to see who has the most compact external wastegates .
Cheers A .
do you have a link where anyone has done a direct comparison with say a .63 vs the .78 twin scroll?
I've looked at it a few times and wondered how it would perform on my hks manifold with a 56 trim 3071
No and those looking at this stuff are in the US and working with SR20DET's and KA24DE+T's . Not the same as an RB six but I like to look at things from an individual cylinder capacity point of view .
Jeff Raicer who posts here occasionally has put a lot of effort into micky mouse split pulse exhaust manifolds and twin scroll turbos and says he can get big turbos to spool more like smaller ones do with single entry turbine housings . I'd say it has a lot to do with getting the most advantage from the exhaust gas energy innitially ie when the valves first crack open into an area of low restriction and reasonably low pressure . So hopefully low restriction and best energy gain by the turbine so least pumping losses/reversion and more ignition timing to make the most efficient use of the charge air and fuel .
You can find him at FullRace.com and there is a forum there .
Cheers A .
Edited by discopotato03
There are some good reads on the net about this stuff . Search PDX Tuning Results with GT32 Turbokit and APS twin scroll rotated mount turbo system model designation TSR 70 . There's a lot of wading through the dross on this 2nd one , APS has made a split pulsed manifold kit and sells a GT3582R (with fancy drilled port shrouded comp housing like the TO4Z at ATP's site) with a petrol material spec (read high temp capable) twin entry .82 A/R T3 flanged Garrett turbine housing and 3.5" V band outlet) as part of the kit . It uses a single TiAL external gate fed by twin pipes sort of like the pic in the last post . If you don't have half an hour to read through it they're hinting that it spools up ~ 400 odd rpm sooner than a normal GT35 .82 turbine housing - on an EJ25 anyway .
More later cheers A .
i too would be keen to know what kind of gains can be had converting to the twin entry turbine housing.
after all a gt30r on a rb20 isnt exactly the fastest spooling thing in the world and the hks cast manifold is already setup for twin entry...
Hi Carl , there is not as much out there in the way of T3 flanged twin entry housings for GT30BB turbos as I had hoped .
A couple of interesting things though . First Garrett have had for ages a series of GT bush bearing turbos called GT32 ie GT3267 and GT3271 . They use either a .69 or a .78 A/R turbine housing with 70 or 73 trim turbines . They are reasonably cheap and not a bad thing for approx 350+ wheel Hp .
Secondly ATP in the States appears to be machining these housings to fit the real GT3071R turbo in .78 A/R . You really need a larger A/R version of this housing for a GT3076R and while there's a few different types out there I dont have their details . I've been looking into TA/TB34 housings but nothing screaming eureka yet .
With your RB20 I don't know where to go with a GT3076R , they are not easy to excite with an RB25 and single entry housings (not without small turbine housings anyway) . The smallest propper housing I know of for that turbo is the HKS .61 A/R and it is non gated and T28 flange . You could try ATPs divided housings but its a lot of stuffing around plus an external gate and still may not get you what you want . Selling the GT30 and buying a GT28 based turbo like a 2530 may be a better solution .
Your call .
wouldnt you need a suitable split pulse manifold to actually benefit from the twin scroll design? or there is some gains to be had from just twin scroll and if you can run split pulse (sr20) then its even better?
split pulse manifold and split pulse housing (all else being equal) is always better than open collector and open housing. less turbulence at the gas merge, less chance of a cylinder's exhaust valve being caught open when another one is pulsing as well (so less pressure spike variations across all cylinder's exhaust runners = lower average backpressure when the valve is open).
i would only go an open collector if it was significantly cheaper, or there was no other choice. manifold must be split pulse as well though.
well ive already got the gt3076r mounted onto a hks cast manifold with an external gate...so that really isnt a problem.
im currently running the .63 ar 't' 2.5" outlet and it comes on full song round 4.1k give or take.
would the divided entry help in spool time some, i dont want to plunk down the coin only to have a slower spooling turbo.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
