I been noticing alot of places now offering the higher octane rated fuels, must be the trend with all the youngn's fillin up their "Mugen/Honda" '83 Civic "type R" with 98 Octane fuel :)
But seriously its great more places are stocking it, my car runs like a complete dog on regular, unfortunately had to put some in one day, due to lack of premium in the middle of nowhere!
https://www.sau.com.au/forums/topic/15779-good-petrol-news-for-import-owners/
why is it that optimax seems to be at least 5c mroe expensive per litre than 8000 or ultimate? everyone i speak to swears by optimax but if they're all 98RON then i don't see how optimax could be that much better. must be good advertising techniques...
i use 8000 because it is 300m away, and also because the BP near me only has 96RON stuff but next to uni has BP ultimate and after recently trying it i give it two thumbs up.
Waz.
i herd that optixmax goes off much more quicker than other high octain fuels i mean every fuel has a due by date but i herd that optimax only has about 4 to 6 days so that could be it i guess =)
i read it some where here
well ihave tried s8000 and iam happy would like to still go with ultimate if its around my area
With the exception of Shell, I know of only one BP (that's within 20km of my house) that stocks ULTIMATE.....
Ozzy where do you normally get ur ULTIMATE from? The BP in Phillip or Civic? Man its good to hear more place are poppin up in the ACT/QBYN area sellin the stuff!
I'm running on the limit of detonation with 16psi and just over 20degree's timing.
I find with BP 98 here is SA that I get a slight hessitation and it doesn't seem to hit as hard when boost comes on.
Mobil S8000 however seems to be a lot punchier.
BP 98 when reving out second and clicking third doesn't punch you in the seat where as when I run S8000 it does.
Not sure why but it does.
Vary's with different servo's.
We have a BP down here that is always 6 cents more expensive than ULP. The one around the corner is 9 cents more expensive.
I found that Mobil is generally always around 9-12cents more expensive than ULP.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
