so you've had it in this state of tune for less than 2 months, so what is the reason to sell it so suddenly for, looks like an awsome setup, is it fully tuned yet? all the hassles sorted out?
https://www.sau.com.au/forums/topic/157796-sold/#findComment-2936125
yep its all tuned all the problems fixed except for tailshaft which its holding up alright so far but i just need something more of a daily driver as i now need to drive my car to work and might have to leave it overnight without worrying and at the moment i cannot afford to buy a runabout to get to work and back so i use my wifes car thats why its got to go i really dont want to sell it but 1st things 1st any reasonable offers will be considered dont be shy hehe BTW v&e rigoli tuned the ems in december 06 when the conversion was finished
Edited by NO3RYD
https://www.sau.com.au/forums/topic/157796-sold/#findComment-2936400
  • 3 weeks later...
Last bump car will not be for sale if it doesnt sell by 08/04/07 great car for a great price do not miss out as i said earlier i will be interested on a more basic but new model day to day driver for around the same price or cheaper.
https://www.sau.com.au/forums/topic/157796-sold/#findComment-3020050
Hey dude, any power figures? Have you had much interest, looks like a nice setup and pretty good price.. Good luck with it mate....
To be honest with ya im suprised such a shock i got i thought it would have been gone and id be missing it by now but i havent had any proper intrest in it as yet as for power figures it got dynoed @ 202rwkw but that was only on 5psi low boost coz the fuel pump leaned out but since dyno i have gotten a walbro pump alloy 3 core radiator and boost is set to 9psi not sure of rwkw but pretty sure its around 220rwkw
https://www.sau.com.au/forums/topic/157796-sold/#findComment-3024022
sounds like a nice ride to me.. Have u tried nissansilvia.com?
Yep its listed here nissan silvia and boost might try the paper and carsales see how things go thanx for the compliment on the car ur right its a awesome car with alot of time effort and hard earned cash gone into it.
https://www.sau.com.au/forums/topic/157796-sold/#findComment-3024235
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
