so you've had it in this state of tune for less than 2 months, so what is the reason to sell it so suddenly for, looks like an awsome setup, is it fully tuned yet? all the hassles sorted out?
https://www.sau.com.au/forums/topic/157796-sold/#findComment-2936125
yep its all tuned all the problems fixed except for tailshaft which its holding up alright so far but i just need something more of a daily driver as i now need to drive my car to work and might have to leave it overnight without worrying and at the moment i cannot afford to buy a runabout to get to work and back so i use my wifes car thats why its got to go i really dont want to sell it but 1st things 1st any reasonable offers will be considered dont be shy hehe BTW v&e rigoli tuned the ems in december 06 when the conversion was finished
Edited by NO3RYD
https://www.sau.com.au/forums/topic/157796-sold/#findComment-2936400
  • 3 weeks later...
Last bump car will not be for sale if it doesnt sell by 08/04/07 great car for a great price do not miss out as i said earlier i will be interested on a more basic but new model day to day driver for around the same price or cheaper.
https://www.sau.com.au/forums/topic/157796-sold/#findComment-3020050
Hey dude, any power figures? Have you had much interest, looks like a nice setup and pretty good price.. Good luck with it mate....
To be honest with ya im suprised such a shock i got i thought it would have been gone and id be missing it by now but i havent had any proper intrest in it as yet as for power figures it got dynoed @ 202rwkw but that was only on 5psi low boost coz the fuel pump leaned out but since dyno i have gotten a walbro pump alloy 3 core radiator and boost is set to 9psi not sure of rwkw but pretty sure its around 220rwkw
https://www.sau.com.au/forums/topic/157796-sold/#findComment-3024022
sounds like a nice ride to me.. Have u tried nissansilvia.com?
Yep its listed here nissan silvia and boost might try the paper and carsales see how things go thanx for the compliment on the car ur right its a awesome car with alot of time effort and hard earned cash gone into it.
https://www.sau.com.au/forums/topic/157796-sold/#findComment-3024235
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
