Getting Into Spraying
Selling a SMIC for a Nissan Stagea C34 Series 2 and the pipe from the intercooler to inlet. (I believe it is the same R34 GTT, please correct me if I'm wrong) Price: $50? I dont have a photo of the big black pipe that goes from SMIC outlet to throttle body.
So the original radiator is leaking now. Looking at getting a fully aluminium one next. Am I correct in saying that the Series 2 Auto Stageas have a separate trans cooler from factory (located in between the rad and intercooler in my previous post/message). Currently looking at Fenix $460, Blitz $700, GReddy $800, and KoyoRad $740. What are everyones thought on Fenix ( ive read a few comments saying theyre cheap Chinese rebrands etc and how their build quality is... well.. chinese...) compared to the others? Worth the extra couple hundies?
By soviet_merlin · Posted
Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models... -
Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
