Correct me if I'm wrong, but kilograms per cubic centimetre (kg / cub. cm) is a unit of pressure. Its an oil pressure guage.
The reason the guage drops when it gets to operating temp is because the viscosity of the oil changes when it heats up. More viscous, flows better, less pressure, colder oil, less viscous, more pressure. Something like that :)
/me goes wayyy back to old pre-voc auto tafe classes.....:(
https://www.sau.com.au/forums/topic/15783-oil-pressure-on-rb20-det/
same thing happens to my motor. idle when warm it drops to almost 0.6 or less (seems too low for me), anything over 2000rpm its up to 2.5-3 then after that bumps over 3 and stays there.
i'm gunna hook up a proper oil pressure gauge this week and get some precise readings.
my cam gear is also pretty noisey, at idle you can hear it quitely grinding away... scary!
what grade oil are you guys using?
Karlos
I was told once when I was worried about my 2 litre in my Alfa GTV that with a true reading you won't about 1 kg for every 1000rpm.
It is no secret that R32 oil pressure gauges are in-accurate at the best of times and useless most of the time.
On my R32 as with the others, it reads about 4kg at start up, no matter what the revs. At operating temp it will drop to 1kg at idle and then reads usually nothing until 4000rpm. It will however rise and fall as you boost up a little.
At the end of the day, run a good quality synt oil and only panic if the oil light comes on.
But do change oil regulary because the heat genarated by the turbo and the friction created thru the revs that most of us 32 gts drivers endow upon it will deteriorate its effectiveness very quickly.
When oil is cold it is thicker there4 higher pressure - the reason it shows 4 at all revs is that the pressure relief valve is operating and preventing the pressure from becoming too high - remember thick cold oil = no lubrication so dont boost until the oil is warm - one reason why the GTR has an oil temp gauge.
I used to have that problem when using Ryco Oil filters.
Prior to switching oil filters I did 3 oil changes ever 2000km's.
The oil used to get dirty really quick now it is still clean looking after 5000km's. I also use PureOne Oil filters which for some reason seemed to stop the drop in oil pressure. Prior some times It used to make the red light turn on after a hard run. This may have been due to sludge or crap in the motor who knows.
All I know is it is fixed now after many oil changes.
Guys, I deal with this very issue every day at work...
Different oils, oil viscosity ratings, oil pressure and oil temperature are all related to eachother (obviously).
You can get into very lengthy and often complex discussions involving oils, temps and pressures as there are just too many variables involved to ascertain what is the "right" oil and the "right" oil pressure for each engine and application.
It all comes down to:
1. Type of oil.
2. Quality of oil.
3. Viscosity rating of oil. (there are other ways of judging oil properties, but I will leave this out for this example)
4. Temperature of oil.
5. Accuracy of oil pressure gauge.
6. Condition of the oil pump (if it is worn)
7. Condition of the engine. (if it has badly worn components/clogged galleries, etc)
8. Intended use of the car. (Drag-racing, Track racing, Every day use, etc)
9. Other variables like: engine builder's clearances/tolerances on a freshly built engine.
As you can see, there are just too many variables which affect oil pressure.
But for skylines i always recommend synthetic 5W/40 oil or 0W/40 oil for general use on a daily driven street car which is in good mechanical condition. Oils such as Shell Helix Ultra 5W/40 SL, Mobil 1 Trisynthetic 0W/40 SL, Castrol Formula R 0W/40 SL just to name a few.
For track use, i always recommend a 10W/60 synthetic oil for its ability to withstand higher oil temperatures which then translates to a more stable oil pressure because of its ability to fight "thinning out" like most other lower viscosity oils.
Anyway, i could write a book about oils, etc but i've bored you all enough to death about what things you've got to take into consideration about oils, temps and pressures.
In short, your gauges are showing a lower reading after a hard run generally is due to your oil thinning out due to the higher temp by both your engine and turbo(s).
I have a GREDDY Oil Press Gauge and It reads about 4 BAR @ around 3,000 RPM in fifth on the HWY.
At idle it will go down below 2 BAR (1.5).
I have noticed that after my last service where I put in some better oil, my press is @ 3.9 BAR at the same HWY revs (interesting).
Is this due to the better viscosity of the oil running at slightly less pressure?
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
