Im half way into fitting my trust frount bar iv got a 120mm thick fmic. Now the drama is i have to shave some plastic of my thermo fan so i can push my cooler back more. So im thinking of upgrading the thermo, saves me shaving it, just wondering if its worth it and what is good to use.The car is in the process of getting to make 250-300 kw
Cheers
Dave
https://www.sau.com.au/forums/topic/157841-thermo-fan/
I used a cheapo Ebay special ~$75ish a year or two ago. :)
The origional is 12" I squeezed a 14" in there that flows what feels like more than double.
If you do grab a thermo grab one with an S shaped fan blade. They flow considerably more and are much quieter.
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2931320
im using twin 10 inch daves carigs ( with the curved blades for flow and quietness) and they work really well in my lil crampt engine bay... jus ask any one who has looked under the hood
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2931666
there talking about air con thermo fan. not radiator thermo fan
i dont think Marvin has to worry aboout aircon thermo's
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2931710
I am just about to buy 2 of these
http://cgi.ebay.com.au/HIGH-PERFORMANCE-14...1QQcmdZViewItem
and chuck them in when I fit my new radiator. Also going to put in a Pivot fan speed controller too - temperature controlled thermo is where it's at!
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2932021
no worries cruzin33 we are all here to help :D
sweet Joel - glad to hear you are happy with it. I hoped I could get some feedback before I bought them :laugh:
With 2 x 14" (which will hang an inch over each side of the radiator) I will have 5,300cfm - which is a MASSIVE amount of air! And I will need it since I have a FMIC, putting on an oil cooler and upgraded trans cooler, plus standard a/c radiator, plus the new radiator.
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2932037
After your comment about the a/c pipes I went and checked my engine bay and you are right Joel - I will only just be able to get a 16" fan in there .... bugger .... oh well that will have to do. With the Pivot controller I will be able to control when and how hard it comes on, so will have to ramp it up on hot days accordingly. I am also going to rig it up so the thermo fan keeps running even after the engine is turned off, when the water is over a certain temperature. Since I am in and out of the car all day, and spend long times stationary idling with the a/c on, I need to do this to sort out my temp issues once and for all. On 40 degree days I have seen my water temp reach 115 degrees - yikes!!
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2932060
no idea and no idea. I am pretty handy mechanically so I am sure will be easy for me to install - but I can;t judge your competence :D
I am buying mine from a private someone who is looking to sell one.
I would try online retailers who sponsor SAU and nissansilvia.com if I was you.
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2939883
  • 3 weeks later...
I got the fan the other day took one week for it to turn up and it was worth it. It was packed nice and no probs with the dealer it also aloud me to push my fmic back 25mm. Now just have to find a temperature controlled thermo unit and find a new upgrade radiator, and im set :ermm:
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2985782
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
